When I switch on computer, because I have it encrypted, it always first asks for my passphrase in the GUI. I enter the phrase, then still in the GUI it normally asks for my password, and goes to the GUI desktop.
Now, for some reason, it started going direct to Terminal after I enter the passphrase, with the prompt:
Ubuntu 14.04.3 LTS thomas-All-Series tty1
thomas-All-series login:
I don't know why this started.
After logging in as user (not root), the following pieces of information spew out:
Last login: Sat Jan 9 18:23:13 CST 2016 on tty1
Welcome to Ubuntu 14.04.3 LTS (GNU/Linux 3.13.0-74-generic x86_64)
*Documentation: https://helpubuntu.com
find: '/var/lib/apt//lists/': No such file or directory
/usr/lib/update-notifier/update-motd-updates-available: 39: /usr/lib/update-notifier/update-motd-updates-available: cannot create /var/lib/update-notifier/updates available: Directory nonexistent
cat: /var/lib/update-notifier/updates available: No such file or directory
run-parts: /etc/update-motd.d/90-updates-available exited with return code 1
/usr/lib/ubuntu-release-upgrader/release-upgrade-motd: 39: /usr/lib/ubuntu-release-upgrader/release-upgrade-motd: cannot create /var/lib/ubuntu-release-upgrader/release-upgrade-available: Directory nonexistent
/usr/lib/update-notifier/fsck-at-reboot: 33: /usr/lib/update-notifier/update-motd-fsck-at-reboot: cannot create /var/lib/update-notifier/fsck-at-reboot: Directory nonexistent
cat: /var/lib/update-notifier/fsck-at-reboot: No such file or directory
run-parts: /etc/update-motd.d/98-fsck-at-reboot exited with return code 1
thomas@thomas-All-Series:~$ _
I tried startx $(which unity) in both my username and root to see if there was a difference, and this is the readout I got in both:
(compiz:1347): dconf-WARNING **: failed to commit changes to dconf:
Cannot spawn a message bus without a machine-id:
Unable to load /var/lib/dbus/machine-id or /etc/machine-id:
Failed to open file '/var/lib/dbus/machine-id': No such file or directory
The above message is repeated three times, followed by:
WARN 2016-01-13 20:06:08 unity.glib.dbus.server GlibDBusServer.cpp:579 Can't registe
r object 'org.gnome.Shell' yet as we don't have a connection, waiting for it...
ERROR 2016-01-13 20:06:09 unity.debug.interface DebugBusInterface.ccp:216 Unable to
load entry point in libxpathselect: libxpathselect.so.1.4: cannot open shared object
file: No such file or directory
process 1347: D-Bus library appears to be incorrectly set up: failed to read machine
uuid: Failed to open "/etc/machine-id": No such file or directory
See the manual page for dbus-uuidgen to correct this issue.
ERROR 2016-01-13 20:06:09 unity.launcher.entry.remote.mode1 LauncherEntryRemoteMode1
.cpp:50 Unable to connect to session bus: Cannot spawn a message bus without a machi
ne-id: Unable to load /var/lib/dbus/machine-id or /etc/machine-id: Failed to open fi
CRIT 2016-01-13 20:06:09 unity <unknown>:0 Unable to get org.ayatana.bamf matcher:
Cannot spawn a message bus without a machine-id: Unable to load /var/lib/dbus/machin
e-id or /etc/machine-id: Failed to open file '/var/lib/dbus/machine-id': No such fil
e or directory
Trace/breakpoint trap (core dumped)
xinit: connection to X server lost
waiting for X server to shut down (EE) Server terminated successfully (0). Closing l
og file.
