I am using Ubuntu 15.10 using an Ethernet connection to my cable model router. I have not customized the network set up in any way after installing Ubuntu. I've noticed that after about 12 to 24 hours after booting up, Ubuntu starts to drop internet connections. Usually I notice this after webpages fail to load images or CSS files. When this happens I notice that the /var/syslog is filled with entries like this:
Jan 8 05:26:40 46lbs avahi-daemon[730]: Registering new address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.*.
Jan 8 05:26:40 46lbs avahi-daemon[730]: Withdrawing address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.
Jan 8 05:26:43 46lbs avahi-daemon[730]: Registering new address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.*.
Jan 8 05:26:43 46lbs avahi-daemon[730]: Withdrawing address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.
Jan 8 05:26:46 46lbs avahi-daemon[730]: Registering new address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.*.
Jan 8 05:26:46 46lbs avahi-daemon[730]: Withdrawing address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.
Jan 8 05:26:49 46lbs avahi-daemon[730]: Registering new address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.*.
Jan 8 05:26:49 46lbs avahi-daemon[730]: Withdrawing address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.
Jan 8 05:26:52 46lbs avahi-daemon[730]: Registering new address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.*.
Jan 8 05:26:52 46lbs avahi-daemon[730]: Withdrawing address record for 2605:e000:850e:8800:d9cb:5166:bac1:61d2 on eth0.
Usually I can recover normal internet use by disconnecting the wired connection using the networking icon in the Ubuntu toolbar and then reconnecting. However, this is troublesome. I would like to keep the avahi-daemon for the purposes of discovery. Does anyone know how to stop this behavior? For the record, here is the output of my ifconfig
eth0 Link encap:Ethernet HWaddr 08:62:66:7c:ea:35
inet addr:192.168.0.4 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: 2605:e000:850e:8800:8729:2a19:e7c8:5738/128 Scope:Global
inet6 addr: fe80::a62:66ff:fe7c:ea35/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4638380 errors:0 dropped:9 overruns:0 frame:0
TX packets:2164811 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5378789738 (5.3 GB) TX bytes:231746518 (231.7 MB)
Interrupt:20 Memory:fb200000-fb220000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:40049332 errors:0 dropped:0 overruns:0 frame:0
TX packets:40049332 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2898153546 (2.8 GB) TX bytes:2898153546 (2.8 GB)
