So, I had bought a new laptop which came preinstalled with Ubuntu 14.04 but I later installed Windows 10 after removing Ubuntu, I backed up laptop vendor's Ubuntu image though which came on the laptop.
Later, I decided to have a dual boot configuration so I installed Ubuntu using the same vendor image I had backed up. Ubuntu installed succesfully but now I am unable to boot into Windows as it is not showing up as an entry in grub.
I tried boot-repair but it doesn't seem to work. Although I got the url http://paste.ubuntu.com/14429794/ It keeps repeating the message to 'unmount partitions' even in a live-usb system. I then tried bootscriptinfo which gave the output given below.
Also, I am sure that the whole windows partition is intact as I can see all the files in Ubuntu, it's just that I can't boot from it.
EDIT: I also tried the setroot method in the grub command line but it gave an error saying that the EFI path is not valid.
Any help would be greatly appreciated as I have already spent much time scouring forums and searching on Google.
Boot Info Script 0.61 [1 April 2012]
============================= Boot Info Summary: ===============================
=> Windows is installed in the MBR of /dev/sda.
=> Syslinux MBR (4.04 and higher) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
File system: vfat
Boot sector type: Unknown
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /efi/Boot/bootx64.efi /efi/ubuntu/grubx64.efi
/efi/ubuntu/MokManager.efi /efi/ubuntu/shimx64.efi
sda2: __________________________________________________________________________
File system: vfat
Operating System:
Boot files:
sda3: __________________________________________________________________________
File system: vfat
Operating System:
Boot files: /boot/grub/grub.cfg /efi/boot/bootx64.efi
/efi/boot/grubx64.efi
sda4: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Mounting failed: mount: wrong fs type, bad option, bad superblock on /dev/sda4,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
sda5: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista/7: NTFS
Operating System:
Boot files: /bootmgr /Windows/System32/winload.exe
sda6: __________________________________________________________________________
File system: ntfs
Operating System:
Boot files:
sda7: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 14.04 LTS
Boot files: /boot/grub/grub.cfg /etc/fstab
/boot/extlinux/extlinux.conf
sda8: __________________________________________________________________________
File system: ntfs
Operating System:
Boot files:
sda9: __________________________________________________________________________
File system: ntfs
Operating System:
Boot files:
sda10: _________________________________________________________________________
File system: ntfs
Operating System:
Boot files:
sda11: _________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sdb1: __________________________________________________________________________
File system: vfat
Boot sector type: SYSLINUX 4.05 20140113
Boot sector info: Syslinux looks at sector 10154144 of /dev/sdb1 for
its second stage. SYSLINUX is installed in the
directory. No errors found in the Boot Parameter Block.
Operating System:
Boot files: /boot/grub/grub.cfg /syslinux.cfg
/efi/BOOT/bootx64.efi /efi/BOOT/grubx64.efi /bootmgr
/boot/bcd /ldlinux.sys
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 1 1,953,525,167 1,953,525,167 ee GPT
GUID Partition Table detected.
Partition Start Sector End Sector # of Sectors System
/dev/sda1 2,048 1,026,047 1,024,000 EFI System partition
/dev/sda2 1,026,048 1,107,967 81,920 -
/dev/sda3 1,107,968 7,399,423 6,291,456 Data partition (Windows/Linux)
/dev/sda4 7,399,424 7,432,191 32,768 Microsoft Reserved Partition (Windows)
/dev/sda5 7,432,192 132,347,903 124,915,712 EFI System partition
/dev/sda6 132,347,904 133,269,503 921,600 Windows Recovery Environment (Windows)
/dev/sda7 133,269,504 238,127,103 104,857,600 Data partition (Windows/Linux)
/dev/sda8 238,127,104 868,321,279 630,194,176 Data partition (Windows/Linux)
/dev/sda9 868,321,280 1,393,657,855 525,336,576 Data partition (Windows/Linux)
/dev/sda10 1,393,657,856 1,918,994,431 525,336,576 Data partition (Windows/Linux)
/dev/sda11 1,918,994,432 1,953,523,711 34,529,280 Swap partition (Linux)
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 16.2 GB, 16219373568 bytes
255 heads, 63 sectors/track, 1971 cylinders, total 31678464 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
/dev/sdb1 * 63 31,678,463 31,678,401 c W95 FAT32 (LBA)
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/sda1 008D-EE2D vfat ESP
/dev/sda10 5430D21630D1FF44 ntfs New Volume
/dev/sda11 8b83b838-ad2b-4260-94b4-9480fd5b947d swap
/dev/sda2 0800-FF07 vfat DIAGS
/dev/sda3 A801-BD4C vfat OS
/dev/sda4 7722aa47-a14c-4c99-a04e-8d5485dcbacc ext4
/dev/sda5 C6026F98026F8C6D ntfs
/dev/sda6 BED4F2F6D4F2AFAF ntfs
/dev/sda7 532c4cae-d2a5-49c8-8663-0af5e26cad1f ext4
/dev/sda8 16EC940EEC93E5F1 ntfs New Volume
/dev/sda9 9696C50A96C4EBB5 ntfs New Volume
/dev/sdb1 BE1A-5D9E vfat
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sda10 /media/sachinkadyan7/New Volume1 fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sda1 /boot/efi vfat (rw)
/dev/sda5 /media/sachinkadyan7/C6026F98026F8C6D fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sda6 /media/sachinkadyan7/BED4F2F6D4F2AFAF fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sda7 / ext4 (rw,errors=remount-ro)
/dev/sda9 /media/sachinkadyan7/New Volume fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sdb1 /media/sachinkadyan7/BE1A-5D9E vfat (rw,nosuid,nodev,uid=1001,gid=1001,shortname=mixed,dmask=0077,utf8=1,showexec,flush,uhelper=udisks2)
=========================== sda3/boot/grub/grub.cfg: ===========================
# Dell Grub2 configuration file for ISO Images #
# By: Mario Limonciello #
# First check for additional options on ISO image
if [ -s /factory/common.cfg ]; then
source /factory/common.cfg
fi
#Post RTS deliverables
if [ -s /factory/post-rts-gfx.cfg ]; then
source /factory/post-rts-gfx.cfg
fi
if [ -s /factory/post-rts-wlan.cfg ]; then
source /factory/post-rts-wlan.cfg
fi
# If missing, load a nice basic default set
if [ -z "${options}" ]; then
set options="boot=casper automatic-ubiquity noprompt quiet splash --"
fi
# Setup theme
set timeout=5
set gfxmode=auto
insmod gfxterm
terminal_output gfxterm
loadfont /boot/grub/dejavu-sans-12.pf2
loadfont /boot/grub/dejavu-sans-bold-14.pf2
insmod gfxmenu
insmod png
set theme=/boot/grub/dell/theme.txt
# Search for the RP (which contains grubenv in /factory)
search --file --set=new_root /factory/grubenv
if [ -s ($new_root)/factory/grubenv ]; then
set have_grubenv=true
load_env -f ($new_root)/factory/grubenv
if [ -n "${install_finished}" ]; then
set timeout=-1
menuentry "Install Complete, remove media and reboot." {
chainloader +1
fi
if [ "x${install_in_progress}" = "x1" ]; then
set root=$new_root
configfile ($new_root)/factory/grub.cfg
fi
fi
#Default behavior
menuentry "Dell Recovery" {
set gfxpayload=keep
linux /casper/vmlinuz.efi $options
initrd /casper/initrd.lz
menuentry "Dell Recovery (safe graphics mode)" {
set gfxpayload=keep
linux /casper/vmlinuz.efi $options ubiquity/force_failsafe_graphics=true
=================== sda3: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
=========================== sda7/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod ext2
set root='hd0,gpt7'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt7 --hint-efi=hd0,gpt7 --hint-baremetal=ahci0,gpt7 532c4cae-d2a5-49c8-8663-0af5e26cad1f
else
search --no-floppy --fs-uuid --set=root 532c4cae-d2a5-49c8-8663-0af5e26cad1f
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_IN
insmod gettext
fi
if [ "${recordfail}" = 1 ] ; then
set timeout=-1
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=0
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 0 ; then
set timeout=0
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 44,0,30; then
clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-532c4cae-d2a5-49c8-8663-0af5e26cad1f' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt7'
else
fi
linux /boot/vmlinuz-3.13.0-38-generic.efi.signed root=UUID=532c4cae-d2a5-49c8-8663-0af5e26cad1f ro quiet splash radeon.modeset=0 nouveau.modeset=0 $vt_handoff
initrd /boot/initrd.img-3.13.0-38-generic
submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-532c4cae-d2a5-49c8-8663-0af5e26cad1f' {
menuentry 'Ubuntu, with Linux 3.13.0-38-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.13.0-38-generic-advanced-532c4cae-d2a5-49c8-8663-0af5e26cad1f' {
recordfail
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt7'
else
fi
echo 'Loading Linux 3.13.0-38-generic ...'
echo 'Loading initial ramdisk ...'
menuentry 'Ubuntu, with Linux 3.13.0-38-generic (safe mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.13.0-38-generic-recovery-532c4cae-d2a5-49c8-8663-0af5e26cad1f' {
recordfail
load_video
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt7'
else
fi
linux /boot/vmlinuz-3.13.0-38-generic.efi.signed root=UUID=532c4cae-d2a5-49c8-8663-0af5e26cad1f ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'System setup' $menuentry_id_option 'uefi-firmware' {
fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda7/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# / was on /dev/sda7 during installation
UUID=532c4cae-d2a5-49c8-8663-0af5e26cad1f / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda1 during installation
UUID=008D-EE2D /boot/efi vfat defaults 0 1
# swap was on /dev/sda11 during installation
UUID=8b83b838-ad2b-4260-94b4-9480fd5b947d none swap sw 0 0
====================== sda7/boot/extlinux/extlinux.conf: =======================
## /boot/extlinux/extlinux.conf
## IMPORTANT WARNING
## The configuration of this file is generated automatically.
## Do not edit this file manually, use: extlinux-update
default l0
prompt 1
timeout 50
include themes/debian/theme.cfg
=================== sda7: Location of files loaded by Grub: ====================
================= sda7: Location of files loaded by Syslinux: ==================
============== sda7: Version of COM32(R) files used by Syslinux: ===============
boot/extlinux/chain.c32 : COM32R module (v4.xx)
=========================== sdb1/boot/grub/grub.cfg: ===========================
if loadfont /boot/grub/font.pf2 ; then
set gfxmode=auto
insmod efi_gop
insmod efi_uga
insmod gfxterm
fi
menuentry "Try Ubuntu without installing" {
set gfxpayload=keep
linux /casper/vmlinuz.efi file=/cdrom/preseed/ubuntu.seed boot=casper quiet splash --
menuentry "Install Ubuntu" {
set gfxpayload=keep
linux /casper/vmlinuz.efi file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash --
menuentry "OEM install (for manufacturers)" {
set gfxpayload=keep
linux /casper/vmlinuz.efi file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash oem-config/enable=true --
menuentry "Check disc for defects" {
set gfxpayload=keep
linux /casper/vmlinuz.efi boot=casper integrity-check quiet splash --
