I have Ubuntu 14.04LTS and a HP Pavilion dv6500. My computer doesn't remember the amount of brightness everytime I turn it on. Can somebody help me with some terminal command lines?
Thank you.
Please try this command:
echo 2500 | sudo tee /sys/class/backlight/intel_backlight/brightness
More info, please look in this thread How to change LCD brightness from command line (or via script)?
Catur
I use xbacklight to do this, which is simple and works perfectly.
Install it via terminal:
sudo apt-get install xbacklight
Then, I have a command set to run on startup:
xbacklight -set 0
(replacing 0 with whatever brightness level you'd like, 0 to 100)
Hope this helps!
