Things i Have tried.
Playing Blu-Ray and HD DVD Video
MakeMKV and DumpHD do not work.
Playing Blu-ray using VLC
Can linux play blu-rays
VLC error.
Your input can't be opened:
VLC is unable to open the MRL 'bluray:///dev/sr0'. Check the log for details.
MakeMKV Beta Log (last 9 lines)
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Highest AACS version is v25 , MKB saved as /home/neil/.MakeMKV/MKB_v25_Battleship.tgz
The volume key is unknown for this disc - video can't be decrypted
Failed to open disc
DumpHD 0.61 Log.
Initializing source...
Disc type found: Blu-Ray BDMV
Collecting input files...
Source initialized
Identifying disc... OK
DiscID : 5CECDB072DC072F543F734AA708ADCCD4AF7EDDB
Searching disc in key database...
Disc not found in key database
mplayer
xubuntu@xubuntu:~$ mplayer /media/xubuntu/BATTLESHIP_G51/BDMV/STREAM/00023.m2ts
MPlayer 1.1-4.8 (C) 2000-2012 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /media/xubuntu/BATTLESHIP_G51/BDMV/STREAM/00023.m2ts.
libavformat version 54.20.3 (external)
Exiting... (End of file)
xubuntu@xubuntu:~$
VLC error
No suitable decoder module:
VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this.
Neil
  • 4,585
