My laptop has this card, what should I do? What version of linux should I get?
Actually there were/are problems with the Wifi chipset RTL8723BE. Here is a link to my blog post describing couple of my attempts to solve this with different kernels:
https://artofcode.wordpress.com/2017/08/29/problems-with-wifi-signal-under-linux/
One conclusion: newest kernel doesn't automatically mean better support for this chipset.
It's not that bad if you can use antenna selection configuration. If I recall correctly this was the case with some kernels in versions 4.15.0-X where X < 33. With the kernel 4.15.0-33 you need to compile a kernel module which may be not obvious for less advanced users.
In worst case it was like that: antenna selection configuration was ignored and source code of an alternative kernel module was not compatible with the kernel...
The best is to try different Linux kernels using live versions.
I think it is supported from linux 3.13 ....
Install ubuntu 15.10 (which has kernel 4.2)
Aadhil
  • 394
According to this answer, the Linux kernel includes a driver for the RTL8723BE wireless network adapter chipset since (at least) version 3.13, which is included in Ubuntu 14.04 LTS. Alternatively the most recent release 15.10 has a newer kernel version that should work just as well.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
