26
Following command outputs only first 25 characters of the process name (cmd) on the screen. How do I get it to display the full process name?
 ps -eo pid,cmd,etime
hvs
  • 363
The simplest thing you can do is swap the order of outputs: if cmd is last, it will be extended to the full width of the terminal:
ps -eo pid,etime,cmd
If that's still not sufficient, you can add a -w (wide) output modifier
ps -ewo pid,etime,cmd
An additional w gives even wider output
ps -ewwo pid,etime,cmd
(In both of these cases, the output may be wrapped by the terminal.) If you really must have the original field order, then you can specify an explicit width for the cmd field using the syntax field:width e.g.
ps -eo pid,cmd:80,etime
This can be combined with the -w flag(s) if necessary e.g.
ps -ewo pid,cmd:160,etime
The width of a particular output column can also be forced wider by using a longer header string e.g.
ps -eo pid,cmd=my_very_very_very_long_command_that_I_want_to_see_more_of,etime
steeldriver
  • 142,475
Pipe the output to cat.
ps -eo pid,cmd,etime | cat
Anthony Hayward
  • 207
ps -A  -o pid,user:20,%cpu,%mem,comm,args
Nir Duan
  • 129
