I'm trying to plot a 3D graph with Maple on Ubuntu 14.04, but I get the following error:
Maple is unable to render 3D graphics
Your operating system, graphics, or video driver may require updating
see "gldriver" in the help system for more information
GLException
Unable to create OpenGL context
The Maple website recommends the following solution:
Maple is attempting to use hardware rendering but is unable to properly access the graphics hardware. A graphics driver update will likely resolve this.
But I'm not sure how to best proceed with updating the graphic driver since my system is up to date. Can anybody help me to solve this problem?
Here is the output of inxi -AG
Graphics:  Card: Intel Haswell-ULT Integrated Graphics Controller
       X.Org: 1.17.1 drivers: nvidia,intel Resolution: 1366x768@60.0hz
       GLX Renderer: GeForce 820M/PCIe/SSE2 GLX Version: 4.4.0 NVIDIA 340.96
Here is the output of lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b)
and lspci | grep 3D
08:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/820M / GT 620M/625M/630M/720M] (rev a1)
Hunter
  • 482
Step 1 : Uninstall the currently installed drivers 340.
Open a terminal and execute :
sudo apt-get purge nvidia*
sudo reboot
Step 2 : Install the latest stable NVIDIA drivers 352.
sudo apt-get update
sudo apt-get install nvidia-352 nvidia-prime
sudo reboot
In case it does not work install the latest official drivers 358.
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-358 nvidia-prime
sudo reboot
In case it still does not work use another installation method.
Highlight the Ubuntu entry in the GRUB boot menu and press the E key.
Add nouveau.modeset=0 to the end of the linux line - press F10 to boot.
On login screen press Ctrl+Alt+F1 ... enter user name and password ...
Now execute the commands ...
cl-netbox
  • 31,491
First of all, before doing anything.. try "glxinfo | grep OpenGL" and "glxgears" and post output, if they show an error, then your drivers are broken.
According to the output of lspci | grep VGA and 3D you have 1 intel and 1 nvidia card which means OPTIMUS.
i suggest you uninstall purge everything related to the nvidia-drivers, and install bumblebee.
sudo apt-get remove --purge nvidia-prime nvidia-358
sudo add-apt-repository ppa:bumblebee/stable
sudo apt-get install bumblebee bumblebee-nvidia nvidia-358 nvidia-settings primus
then you need to sudo gedit /etc/modules and add
i915
bbswitch
in order to load the intel driver and the bbswitch module( which controls if your card is on or off)
then you need to sudo gedit /etc/modprobe.d/bumblebee.conf and make sure the line
blacklist nvidia-358
is there, if not add it.
That prevents nvidia-358 to be loaded on boot interfering with the intel one.
finally you need to sudo gedit /etc/bumblebee/bumblebee.conf
line 22: >Driver=nvidia
line 55: >KernelDriver=nvidia-358
line 58: >LibraryPath=/usr/lib/nvidia-358:/usr/lib32/nvidia-358
line 61: >XorgModulePath=/usr/lib/nvidia-358/xorg,/usr/lib/xorg/modules
to make the nvidia opengl libraries visible to "optirun"/"primusrun".
reboot.
put in terminal:
and:
primusrun glxinfo | grep OpenGL
Explanation: "primusrun" (or "optirun") executes the given program in the nvidia card.
If both run successfully (they should), then your OpenGL drivers should work correctly and you should be able to run maple, else please post any error outputs of those terminal commands.
if one of them (for some strange reason) doesnt work, try running maple with the working one to see if it works!
See more here: http://rajat-osgyan.blogspot.gr/2015/05/how-to-install-latest-nvidia-driver-in.html
Samsung NP550P5C-S02GR Intel Core i5-3210M HD 4000, Nvidia Geforce GT 650M Ubuntu 14.04.3
