I am trying to install phpmyadmin along with LAMP stack but when I write to the terminal sudo apt-get install phpmyadmin I get this errors :
     phpmyadmin : Depends: php5-mysql but it is not going to be installed or
                   php5-mysqli but it is not installable or
                   php5-mysqlnd but it is not going to be installed
          Recommends: php5-gd but it is not going to be installed
I tried to install php5-gd and I got this error :
 php5-gd : Depends: php5-common (= 5.6.11+dfsg-1ubuntu3) but 5.6.11+dfsg-1ubuntu3.1 is to be installed
I have php5-common already install I tried to install 5.6.11+dfsg-1ubuntu3.1 but I get the there package is not found .
Alex Jones
  • 8,192
