On Ubuntu 14.04, I am getting the error "The value for the SHELL variable was not found the /etc/shells file" when running pkexec to run a script.
Most likely this error started after I removed the fish shell, that was set as my default shell.
The content of /etc/shells is:
# /etc/shells: valid login shells
/bin/sh
/bin/dash
/bin/bash
/bin/rbash
How may I fix this?
kos
  • 41,268
J. Doe
  • 53
The problem is this one: pkexec is accessing $SHELL to determine which shell to use to evaluate the remainder of the command; since you uninstalled fish but didn't do anything else, $SHELL still contains /usr/bin/fish, but pkexec doesn't deem /usr/bin/fish as a valid shell, since /usr/bin/fish has been removed from /etc/shells.
You need to do these two things:
  1. Set a new shell for your user, so that the next time the environment is load $SHELL will contain a path to a valid shell. E.g. to set Bash as the new shell for your user (replace user with your user's username):
    sudo chsh -s /bin/bash user
  2. Log out / log in to reload the environment so that $SHELL contains the path to the new shell for your user.
kos
  • 41,268
