42
I have been building freerpd client for Eclipse in Ubuntu 14.04 but an error is popping up :
Could NOT find PkgConfig (missing:  PKG_CONFIG_EXECUTABLE)
when I use CMake 2.8. How can I get rid of it?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Try:
sudo apt-get install pkg-config
I ran into this nuts problem while compiling opencv. The problem is that CMake is not finding the pkg-config executable.
Fix like this:
1)In ubuntu terminal,
which pkg-config
You will get "usr/bin/pkg-config" if it's installed
2) Add
set(PKG_CONFIG_EXECUTABLE "/usr/bin/pkg-config")
to your Cmake file, or in your build directory, run "cmake-gui" to add it using the GUI. Now, Cmake will find the pkg-config.
https://github.com/vitalif/grive2/issues/74
SOLUTION that worked for me:
sudo apt-get install --reinstall pkg-config cmake-data
Gryu
  • 8,002
  • 37
  • 53
