I need to insatll libapache2-mod-passenger on apache2.4
root@server:~# apt-get install libapache2-mod-passenger
The following packages have unmet dependencies.
libapache2-mod-passenger : Depends: apache2-mpm-worker (>= 2.2.9-9) but it is not going to be installed or
apache2-mpm-prefork (>= 2.2.9-9) but it is not going to be installed or
apache2-mpm-itk (>= 2.2.9-9) but it is not going to be installed
If I try to install the mpm-worker it tries to remove apache.
apt-get install apache2-mpm-worker
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
apache2.2-bin apache2.2-common
Suggested packages:
apache2-doc apache2-suexec apache2-suexec-custom
The following packages will be REMOVED
apache2 libapache2-mod-php5
The following NEW packages will be installed
apache2-mpm-worker apache2.2-bin apache2.2-common
0 to upgrade, 3 to newly install, 2 to remove and 10 not to upgrade.
Need to get 1,572 kB of archives.
After this operation, 5,356 kB disk space will be freed.
Do you want to continue [Y/n]? n
Abort.
How can I install libapache2-mod-passenger?
