14
Help how do I open this. the README file says
THIS DIRECTORY HAS BEEN UNMOUNTED TO PROTECT YOUR DATA.
From the graphical desktop, click on:
 "Access Your Private Data"
or
From the command line, run:
 ecryptfs-mount-private
How do I run this so that I can get my data?
Jjed
  • 14,064
Rebecca H
  • 141
You are trying to access data from an encrypted directory. To do this, log in as the user owning the data in question (eg sally for /home/sally). If the home directory itself is encrypted, logging in will automatically decrypt the data. If it is a Private directory, there should be a launcher in that folder to click (which may again prompt you for the user password).
If the "Access Your Private Data" launcher fails for some reason, use this command and follow instructions:
If, for some reason, you have the data in question independent of the system it was used in, you will need the private key that Ubuntu's encryption wizard asked you to save on installation.
If you have neither the password for user with that encrypted directory, nor the private key, I'm afraid there is no way to recover the data.
Jjed
  • 14,064
This bug happens quite frequently for me on Mint 19.1 Cinnamon for some reason, and without any obvious cause (except time). I find that running the command in an already open terminal does not work. However this works for me:
  1. Open a new terminal windows (don't use an old one)
  2. Run ecryptfs-mount-private without sudo. If it worked, there is no output in the console (no error, no asking for password).
  3. Refresh the files in file browser (nemo) to ensure it worked.
Try logging into as the "USER" whose directory you are trying to access. I faced similar problem when accessing information of that of "user" logging in as a "root" user.
Aditya
