I was configuring my local Ubuntu installation (14.04 LTS). I got this error while trying to run apt-get. I have seen many answer regarding this issue. None of a single answer solve my issue. So I have decided to post a question even many duplicates exists. See my answer below.
I post my answer without editing my question because most of us like me only see the answer section. So here how I fixed my issue:
I was using 2 terminal and I forgot that I was installing another software while trying to run another apt-get (installing on Ubuntu Software Center will cause the same), so I wait until the installation completed. After that no error occurred.
If this is not one your case then you can follow other answer:
  1. Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?
  2. Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?
Hope this will help others.
