I just completed my dual boot with ubuntu 14.04 and windows 8.1.
There was no option to install ubuntu along side with windows so I used the something else option.
I had shrunk my C drive and got 215 gb of free space and used all that space for ubuntu. I could not get option to allocate swap so i didnt use swap.
After the completion of installation my computer boots only to Ubuntu. There is no option to choose windows.
Can any one help me to solve the problem.
I had my UEFI boot option off.
andy256
  • 229
Bikram
  • 111
You will need to update your grub boot options. Open your shell from either the menu, or by pressing the global keyboard shortcut Ctrl+Alt+T, and enter the following command:
sudo update-grub
Upon reboot you should have a timer, and the full list of installed operating systems on your computer.
Siraj
  • 111
I had the same problem back in 12.04, I solved it by installing the rEFInd Boot Manager. If you have a UEFI system (it most likely is if it came with Windows) this might work.
To install rEFInd:
$ sudo apt-add-repository ppa:rodsmith/refind
$ sudo apt-get update
$ sudo apt-get install refind
It will ask you if you want to install rEFInd to your ESP, say yes.
Reboot to save changes.
More info can be found here
