Ubuntu 14.04 host is running virtualbox 4.3.34_Ubuntu r104062. There is an ubuntu 15.10 client which, when running, has a small window size. And it will not expand to full window when using the virtualbox -> View -> Switch to Fullscreen. How can this be fixed?
The standard solution to this is to install vboxadditions and reboot, then try it again. (for instance see http://ubuntuforums.org/showthread.php?t=1042494 ) But this does not work.
When I examine the vboxadditions install messages, there is the following:
Verifying archive integrity... All good.
Uncompressing VirtualBox 4.3.10 Guest Additions for Linux............
VirtualBox Guest Additions installer
Removing installed version 4.3.10 of VirtualBox Guest Additions...
Copying additional installer modules ...
Installing additional modules ...
Removing existing VirtualBox non-DKMS kernel modules ...done.
Building the VirtualBox Guest Additions kernel modules
The headers for the current running kernel were not found. If the following
module compilation fails then this could be the reason.
Building the main Guest Additions module ...done.
Building the shared folder support module ...fail!
(Look at /var/log/vboxadd-install.log to find out what went wrong)
Doing non-kernel setup of the Guest Additions ...done.
Installing the Window System drivers
Warning: unknown version of the X Window System installed.  Not installing
X Window System drivers.
 ...done.
Installing graphics libraries and desktop services components ...done.
Press Return to close this window...
I am wondering if the "unknown version" warning in the install has something to do with the issue?
alangh
  • 143
The error is clear. The output says The headers for the current running kernel were not found. You have two options. You can either install the VirtualBox Guest Additions using the official Ubuntu package (what I recommend), or you can install the kernel headers and try again. I'm going to provide directions for installing the package. Since the VirtualBox Guest Additions have already been packaged, building them from source yourself is just wasted effort.
Anyway, make sure you have all of the standard repositories for Ubuntu 15.10 enabled in your guest, and then run sudo apt-get install virtualbox-guest-dkms linux-headers-generic. This will install the VirtualBox Guest Additions using DKMS, which means that the modules will automatically be rebuilt whenever you get a kernel upgrade.
John Scott
  • 1,472
