When I try to open a project in gnome-builder, whether it's by clicking one of the projects on this screen it starts up on (I have put a big black box over some more private stuff):
"Select a Project" screen in <code>gnome-builder</code>
Or if I use the New button and select an already existing project, it just closes. And over the course of the time that I started the application I have been getting these errors in Terminal:
22:14:57.0356                         libpeas[13410]:  WARNING: Error importing plugin 'html_preview_plugin':
Traceback (most recent call last):
  File "/usr/lib/python3.4/importlib/__init__.py", line 109, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 2254, in _gcd_import
  File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
  File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 1129, in _exec
  File "<frozen importlib._bootstrap>", line 1471, in exec_module
  File "<frozen importlib._bootstrap>", line 321, in _call_with_frames_removed
  File "/usr/lib/x86_64-linux-gnu/gnome-builder/plugins/html_preview_plugin/__init__.py", line 31, in <module>
    from gi.repository import Builder
  File "<frozen importlib._bootstrap>", line 1191, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 1161, in _load_backward_compatible
  File "/usr/lib/python3/dist-packages/gi/importer.py", line 114, in load_module
    introspection_module = get_introspection_module(namespace)
  File "/usr/lib/python3/dist-packages/gi/module.py", line 271, in get_introspection_module
    module = IntrospectionModule(namespace, version)
  File "/usr/lib/python3/dist-packages/gi/module.py", line 120, in __init__
    repository.require(namespace, version)
gi.RepositoryError: Typelib file for namespace 'Ggit', version '1.0' not found
22:14:57.0356                         libpeas[13410]:  WARNING: Error loading plugin 'html_preview_plugin'
22:14:57.0481                         libpeas[13410]:  WARNING: Error importing plugin 'jedi_plugin':
  File "/usr/lib/x86_64-linux-gnu/gnome-builder/plugins/jedi_plugin.py", line 34, in <module>
    from gi.repository import Ide
22:14:57.0481                         libpeas[13410]:  WARNING: Error loading plugin 'jedi_plugin'
22:14:57.0490                         libpeas[13410]:  WARNING: Error importing plugin 'python_gi_imports_completion':
  File "/usr/lib/x86_64-linux-gnu/gnome-builder/plugins/python_gi_imports_completion.py", line 36, in <module>
22:14:57.0490                         libpeas[13410]:  WARNING: Error loading plugin 'python_gi_imports_completion'
And when I ask it to open a project it exists with this final error message:
22:15:39.0312               gb-greeter-window[13410]:  WARNING: Typelib file for namespace 'Ggit', version '1.0' not found
So am I just doing something wrong or is this a bug which I should report?
OS Information:
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 15.10
Release:    15.10
Codename:   wily
Flavour: GNOME
GNOME Version: 3.18
Package Information:
gnome-builder:
  Installed: 3.18.0-0ubuntu1~wily4
  Candidate: 3.18.0-0ubuntu1~wily4
  Version table:
 *** 3.18.0-0ubuntu1~wily4 0
        500 http://ppa.launchpad.net/gnome3-team/gnome3-staging/ubuntu/ wily/main amd64 Packages
        100 /var/lib/dpkg/status
The reason Gnome Builder crashes is that it has a dependency on a Git library but it's not automatically installed when you install Builder (it's this bug specifically). You can get your Gnome Builder to run by manually installing the gir1.2-git2-glib-1.0 package from the repositories for now with:
sudo apt-get install gir1.2-git2-glib-1.0
DCKing
  • 337
