Ubuntu battery icon uses about 1-2 minutes before recognizing charger being plugged in or out. How to make the battery status update more often so that it recognizes the charger immediately.
The problem was not present in Ubuntu 14.10. The problem started with 15.04, and was present in 15.10. I am now on 16.04
I am using a MacBookAir early 2014 model.
You can see that on the picture it says updated and then 99 seconds
And upower -i /org/freedesktop/UPower/devices/battery_BAT0 gives me this when I have unplugged the charger:
native-path: BAT0
vendor: SMP
model: bq20z451
power supply: yes
updated: fr. 01. jan. 2016 kl. 21.29 +0100 (1 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: charging
warning-level: none
energy: 19,2888 Wh
energy-empty: 0 Wh
energy-full: 48,1992 Wh
energy-full-design: 54,34 Wh
energy-rate: 7,3112 W
voltage: 7,868 V
time to full: 4,0 hours
percentage: 36%
temperature: 32,8 degrees C
capacity: 88,6993%
technology: lithium-ion
icon-name: 'battery-good-charging-symbolic'
History (charge):
1451680147 36,000 charging
History (rate):
1451680164 7,311 charging
1451680147 24,183 charging
