I have tried following the suggestions at How do I access an external hard drive plugged into my router? and tried both the usage of smbfs as suggested by the accepted answer(gave problems with smbfs) and cifs (as suggested by @LEO). which resulted in an error mount error(13): Permission denied after sudo mount -a.
The hard drive in question is a mybook external hard drive that has recently been formatted to ntfs (received it this way) and is supposed to function both as a NAS and backup disk. It is attached to a DLINK dir885lr router. When connected via USB rather then network Nautilus doesn't have full access to the disk either but I can use the terminal to operate on the disk. Any solution is welcome and I'm fine with formatting the disk however it would be nice if it remains possible to use it to store backups for a windows and linux system as well as serve as a general dumping ground for files to be shared between systems (multiple partitions?)
