I want to automate pulling git repo and building that repo unattended.
Is there any way I can clone repository and run make immediately after running git clone? Something like:
git clone << myrepo >> && make
An unattended build after a git clone makes not really sense. Most of the time you'll need to install additional libraries beforehand. Partially also configurations are necessary.
If after these adjustments, the project can be built, then you can automate the process, e.g. after a git pull using git hooks.
To use git hooks, place or link a script with the name post-merge in the .git/hooks folder of the project.
A simple post-merge script looks like this:
#!/bin/bash
./configure
make
sudo make install
I have two examples for you that I use myself. The scripts are not perfect. They are illustrative only.:
#!/bin/bash
# A post-merge git hook for
# https://github.com/atom/atom
# ln -s [your_source_folder]/githooks/post-merge/post-merge_4_atom [your_source_folder]/atom/.git/hooks/post-merge
# Trap the INT signal (ctrl-c, for example)
trap trapint 2
packageConfig="package.json"
green="\e[0;32m"
red="\e[0;31m"
TOA="\e[0m" # Turn off character attributes
# Prints OK or FAILED! depending on previous command return value
function okfail () {
if [ $? -gt 0 ]; then
logError "There was an error. Aborting."
return 1
else
logInfo "OK"
return 0
fi
function trapint {
echo
echo
echo "$(basename "$0") SIGINT received"
cleanup
function cleanup {
echo "Cleaning up..."
removeRelease
echo "Bye."
echo
exit 1
function logInfo () {
echo -e "${green}$1${TOA}"
function logError () {
echo -e "${red}$1${TOA}"
function addRelease () {
version=$(jshon -e 'version' < "package.json" | tr -d "\"" | tr -d "\\\\")
release=$(git log | grep -c "^commit")
logInfo "Version: $version"
logInfo "Release: $release"
newVersion="$version-$release"
if [ -f "$packageConfig" ]; then
logInfo "Create backup file $packageConfig.bak"
cp "$packageConfig" "$packageConfig.bak"
okfail; [ $? -gt 0 ] && cleanup
if [ -f "$packageConfig.bak" ]; then
logInfo "Update $packageConfig with $newVersion"
sed -i "s/\"version\" *: *\"$version\"/\"version\": \"$newVersion\"/g" "$packageConfig"
fi
fi
function removeRelease () {
logInfo "Restore file $packageConfig"
mv "$packageConfig.bak" "$packageConfig"
okfail
fi
exec < /dev/tty
while true; do
read -n 1 -p "Compile and install? [y/n]: " yn
echo;
case $yn in
[Yy]* )
break;;
[Nn]* ) exit;;
* ) echo "Please respond with [y]es or [n]o.";;
esac
done
cd ~/src/atom
addRelease
echo -e "${green}compile${TOA}"
script/build
echo -e "${green}build debian packge${TOA}"
script/grunt mkdeb
removeRelease
echo -e "${green}You can find the deb package here: \"/tmp/atom-build\"${TOA}"
ls -la /tmp/atom-build
echo -e "${green}Please install with \"sudo dpkg -i /tmp/atom-build/[deb-package]\"${TOA}"
checkinstall#!/bin/bash
# This program is free software; you can redistribute it and/or modify
# it under the terms of the version 2 of the GNU General Public License
# as published by the Free Software Foundation
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
# Thanks to Felipe Eduardo Sanchez Diaz Duran <izto@asic-linux.com.mx>,
# the author of checkinstall for the many ideas
trap trapint 2
red="\e[0;31m"
green="\e[0;32m"
yellow="\e[0;33m"
bold="\e[0;1m"
# Enable alias expansion in command substitution
shopt -s expand_aliases
# Vefify that we have gettext available
gettext "Bye." &> /dev/null
alias ck_gettext="echo -e"
else
alias ck_gettext="gettext -s --"
fi
## echo with newline at the end
function echog() {
local format="$1"
shift
printf -- "$(ck_gettext "$format")\n" "$@" >&2
## echo with NO newline at the end
function echogn() {
local format="$1"
shift
printf -- "$(ck_gettext "$format")" "$@" >&2
return 1
else
logInfo "OK"
return 0
fi
green="\e[0;32m"
echog "${green}$1${TOA}"
function logWarn () {
yellow="\e[0;33m"
echog "${yellow}$1${TOA}"
red="\e[0;31m"
echog "${red}$1${TOA}"
function trapint {
echo
echo
echog "$(basename "$0") SIGINT received"
cleanup
function cleanup {
echogn "Cleaning up..."
okfail
echog "Bye."
echo
exit 1
function writeDescriptionPak {
if [ "$1" != "" ]
then
echo "$1" > description-pak
fi
function logArchitecture {
echog "\tArchitecture: ${green}$1${TOA}"
function logRequires {
echog "\tRequires: ${green}$1${TOA}"
function logMaintainer {
echog "\tMaintainer: ${green}$1${TOA}"
function logGroup {
echog "\tGroup: ${green}$1${TOA}"
function logSummary {
echog "\tSummary: ${green}$1${TOA}"
function logVersion {
echog "\tVersion: ${green}$1${TOA}"
function logName {
echog "\tName: ${green}$1${TOA}"
function logLicense {
echog "\tLicense: ${green}$1${TOA}"
if [ "$(command -v checkinstall)" == "" ]
then
logError "checkinstall not installed. Aborting."
cleanup
fi
if [ "$(command -v jshon)" == "" ]
then
logError "jshon not installed. Aborting."
cleanup
fi
isGit="1"
if [ ! -d ".git" ]
then
logWarn "No GIT project."
isGit="0"
#cleanup
fi
autogenParam=""
configureParam=""
checkinstallParam=""
projectBasename=$(basename "${PWD}")
configPath="$HOME/.config/postmergerc/$projectBasename"
# Found an old configuration
if [ -f ".git/hooks/postmergerc" ]
then
exec < /dev/tty
while true; do
read -n 1 -p "Old configuration \".git/hooks/postmergerc\" found. Should I copy it to the new location.? [y/n]: " yn
echo;
case $yn in
[Yy]* ) mv ".git/hooks/postmergerc" "$configPath";
okfail; [ $? -gt 0 ] && exit 1
break;;
[Nn]* )
break;;
esac
done
fi
if [ ! -f "$configPath" ]
then
logWarn "\"$configPath\" not found, create a default configuration."
mkdir -p "$HOME/.config/postmergerc"
echo -e "{\n \"autogen\": \"\",\n \"configure\": \"\",\n \"make\": \"\",\n \"checkinstall\": \"\"\n}" > "$configPath"
else
logInfo "\"$configPath\" found"
autogenParam=$(jshon -e 'autogen' < "$configPath" | tr -d "\"" | tr -d "\\\\")
if [ "$autogenParam" != "" ]; then echog "Additional parameters for ${bold}autogen${TOA}"; echog "\t${green}$autogenParam${TOA}"; fi
configureParam=$(jshon -e 'configure' < "$configPath" | tr -d "\"" | tr -d "\\\\")
if [ "$configureParam" != "" ]; then echog "Additional parameters for ${bold}configure${TOA}"; echog "\t${green}$configureParam${TOA}"; fi
makeParam=$(jshon -e 'make' < "$configPath" | tr -d "\"" | tr -d "\\\\")
if [ "$makeParam" != "" ]; then echog "Additional parameters for ${bold}make${TOA}"; echog "\t${green}$makeParam${TOA}"; fi
checkinstallParam=$(jshon -e 'checkinstall' < "$configPath" | tr -d "\"" | tr -d "\\\\")
if [ "$checkinstallParam" != "" ]; then echog "Additional parameters for ${bold}checkinstall${TOA}"; echog "\t${green}$checkinstallParam${TOA}"; fi
echo
fi
# GIT
if [ "$isGit" == "1" ]
then
source=$(git config --get remote.origin.url)
#name=$(echo $source | gawk -F "/" '{print $5}' | sed -e 's/\.git$//')
#name=$(git remote -v | head -n1 | awk '{print $2}' | sed -e 's,.*:\(.*/\)\?,,' -e 's/\.git$//')
name=$(basename $(git config --get remote.$(git config --get branch.master.remote).url) .git)
gitowner=$(echo "$source" | gawk -F "/" '{ print ( $(NF-1) ) }' | gawk -F ":" '{ print ( $(NF) ) }')
#release=$(($(git rev-list HEAD --count)))
responseGitHub=$(curl -s "https://api.github.com/search/repositories?q=+repo:$gitowner/$name")
responseGitHubError=$(echo "$responseGitHub" | jshon -Q -e "errors")
if [ "$responseGitHubError" == "" ]
then
isGitHub="true"
else
isGitHub="false"
fi
fi
if [ "$(command -v easy_install)" != "" ]
then
logWarn "The program \"easy_install\" from the package \"python-setuptools\" is installed. This can make problems with \"checkinstall\"."
fi
exec < /dev/tty
#while true; do
# read -n 1 -p "Show diff? [y/n]: " yn
# echo;
# case $yn in
# [Yy]* ) git diff HEAD^ HEAD;
# break;;
# [Nn]* )
# break;;
# * ) echo "Please respond with [y]es or [n]o.";;
# esac
#done
while true; do
read -n 1 -p "Compile and install $name? [y/n]: " yn
echo;
case $yn in
[Yy]* )
break;;
[Nn]* ) exit;;
esac
done
if [ -f description-pak ]
then
logWarn "Delete description-pak"
if [ -w description-pak ]
then
rm description-pak
else
sudo rm description-pak
fi
fi
if [ -f autogen.sh ]
then
logInfo "Starting autogen.sh"
./autogen.sh "$autogenParam"
fi
if [ -f autogen.sh ] && [ -f configure ]
then
exec < /dev/tty
while true; do
read -n 1 -p "\"autogen.sh\" and \"configure\" found. Should I also run \"configure\"? [y/n]: " yn
echo;
case $yn in
[Yy]* ) logInfo "Starting configure";
./configure "$configureParam"
break;;
[Nn]* )
break;;
esac
done
elif [ -f configure ]
then
fi
if [ -f "Makefile.PL" ]
then
logInfo "Starting perl Makefile.PL"
perl Makefile.PL
fi
if [ -f "Makefile" ]
then
optionRule=-1
while [ "$optionRule" -ne "0" ]
do
makeRules=$(grep "^[a-zA-Z_\-]*:" Makefile | cut -d: -f1)
ruleCount=0
echog "[$ruleCount] continue with \"make\""
for rule in $makeRules
do
ruleCount=$((ruleCount+1))
if [ "$rule" == "install" ]
then
echogn "[$ruleCount] make $rule"
echog " ${yellow}(this is a bad idea)${TOA}"
else
echog "[$ruleCount] make $rule"
fi
done
logInfo "$ruleCount rules found"
echogn "Make your choice or hit return to continue with \"make\": "
read optionRule
if [ -z "$optionRule" ]
then
optionRule=0
else
selectedRule=$(echo "$makeRules" | awk NR=="$optionRule")
logInfo "Starting \"make $selectedRule\""
make "$selectedRule"
fi
done
logInfo "Starting make"
if [ "$makeParam" == "" ]
then
make
else
make "$makeParam"
fi
fi
version=""
maintainer=""
license=""
requires=""
summary=""
group=""
architecture=""
sourceHtmlUrl=""
if [ "$isGitHub" == "true" ]
then
sourceHtmlUrl=$(echo "$responseGitHub" | jshon -e "items" -e 0 -e "html_url")
fi
# DEBIAN/CHANGELOG
if [ -f "debian/changelog" ]
then
echog "Search for information via ${bold}debian/changelog${TOA}"
versionDebianChangelog=$(head -1 "debian/changelog" | gawk -F " " '{print $2}' | tr -d "()")
logVersion "$versionDebianChangelog"
if [ "$version" == "" ]; then version=$versionDebianChangelog; fi
fi
# DEBIAN/CONTROL
if [ -f "debian/control" ]
then
echog "Search for information via ${bold}debian/control${TOA}"
architectureDebianControl=$(grep '^ *Architecture *' "debian/control" | gawk -F ":" '{print $2}' | tr -d " ")
logArchitecture "$architectureDebianControl"
if [ "$architecture" == "" ]; then architecture=$architectureDebianControl; fi
requiresDebianControl=$(grep '^ *Depends *' "debian/control" | gawk -F ":" '{print $2}' | tr -d " ")
logRequires "$requiresDebianControl"
if [ "$requires" == "" ]; then requires=$requiresDebianControl; fi
maintainerDebianControl=$(grep '^ *Maintainer *' "debian/control" | gawk -F ":" '{print $2}' | sed -e 's/^ *//' -e 's/ *$//')
logMaintainer "$maintainerDebianControl"
if [ "$maintainer" == "" ]; then maintainer=$maintainerDebianControl; fi
groupDebianControl=$(grep '^ *Section *' "debian/control" | gawk -F ":" '{print $2}' | sed -e 's/^ *//' -e 's/ *$//')
logGroup "$groupDebianControl"
if [ "$group" == "" ]; then group=$groupDebianControl; fi
summaryDebianControl=$(grep '^ *Description *' "debian/control" | gawk -F ":" '{print $2}' | sed -e 's/^ *//' -e 's/ *$//')
logSummary "$summaryDebianControl"
if [ "$summary" == "" ]
then
summary=$summaryDebianControl
writeDescriptionPak "$summaryDebianControl"
fi
fi
# MAKEFILE
then
echog "Search for information via ${bold}Makefile${TOA}"
versionMakefile=$(grep '^ *PACKAGE_VERSION *= *' Makefile | gawk -F "=" '{print $2}' | tr -d " ")
logVersion "$versionMakefile"
if [ "$version" == "" ]; then version=$versionMakefile; fi
fi
# *.DOAP
if [ -f "$name.doap" ]
then
echog "Search for information via ${bold}$name.doap${TOA}"
lengthMaintainerDoap=$(xpath -q -e "count(//maintainer)" "$name.doap" 2>/dev/null)
for ((i = 1; i <= $lengthMaintainerDoap; i++)); do
if [ "$maintainerDoap" == "" ]
then
maintainerDoap="$(xpath -q -e "//maintainer[$i]/foaf:Person/foaf:name/text()" "$name.doap")"
else
maintainerDoap="$maintainerDoap, $(xpath -q -e "//maintainer[$i]/foaf:Person/foaf:name/text()" "$name.doap")"
fi
maintainerDoap="$maintainerDoap ($(xpath -q -e "string(//maintainer[$i]/foaf:Person/foaf:mbox/@rdf:resource)" "$name.doap" 2>/dev/null | sed 's/^.*mailto:\(.*\)$/\1/'))"
done
logMaintainer "$maintainerDoap"
if [ "$maintainer" == "" ]; then maintainer=$maintainerDoap; fi
summaryDoap=$(xpath -q -e "*/shortdesc/text()" "$name.doap" | tr -d '\n')
logSummary "$summaryDoap"
then
summary=$summaryDoap
writeDescriptionPak "$summaryDoap"
fi
fi
# *.SPEC
if [ -f "$name.spec" ]
then
echog "Search for information via ${bold}$name.spec${TOA}"
licenseSpec=$(grep '^ *License *' "$name.spec" | gawk -F ":" '{print $2}' | tr -d " ")
logLicense "$licenseSpec"
if [ "$license" == "" ]; then license=$licenseSpec; fi
groupSpec=$(grep '^ *Group *' "$name.spec" | gawk -F ":" '{print $2}' | tr -d " ")
logGroup "$groupSpec"
if [ "$group" == "" ]; then group=$groupSpec; fi
summarySpec=$(grep '^ *Summary *' "$name.spec" | gawk -F ":" '{print $2}' | sed -e 's/^ *//' -e 's/ *$//')
logSummary "$summarySpec"
then
summary=$summarySpec
writeDescriptionPak "$summarySpec"
fi
requiresSpec=$(grep '^ *Requires *' "$name.spec" | gawk -F ":" '{print $2}' | tr -d " " | tr '\n' ',' | sed -e 's/^,*//' -e 's/,*$//')
logRequires "$requiresSpec"
if [ "$requires" == "" ]; then requires=$requiresSpec; fi
fi
# SETUP.PY
if [ -f "setup.py" ]
then
if [ ! -x "setup.py" ]
then
echog "${red}setup.py is not executable. Aborting.${TOA}"
exit 1
else
echog "Search for information via ${bold}setup.py${TOA}"
maintainerSetupPy="$(./setup.py --author) ($(./setup.py --author-email))"
logMaintainer "$maintainerSetupPy"
if [ "$maintainer" == "" ]; then maintainer=$maintainerSetupPy; fi
versionSetupPy=$(./setup.py --version)
logVersion "$versionSetupPy"
if [ "$version" == "" ]; then version=$versionSetupPy; fi
licenseSetupPy=$(./setup.py --license)
logLicense "$licenseSetupPy"
if [ "$license" == "" ]; then license=$licenseSetupPy; fi
requiresSetupPy=$(./setup.py --requires)
logRequires "$requiresSetupPy"
if [ "$requires" == "" ]; then requires=$requiresSetupPy; fi
summarySetupPy=$(./setup.py --description)
logSummary "$summarySetupPy"
then
summary=$summarySetupPy
writeDescriptionPak "$summarySetupPy"
fi
fi
fi
# GITHUB API
then
echog "Search for information via ${bold}GitHub-API${TOA}"
summaryGitHubApi=$(echo "$responseGitHub" | jshon -e "items" -e 0 -e "description" | sed -e 's/^"*//' -e 's/"*$//' | tr -d "\\\\")
logSummary "$summaryGitHubApi"
then
summary=$summaryGitHubApi
writeDescriptionPak "$summaryGitHubApi"
fi
fi
# PATH
firstParts=$(echo "$projectBasename" | awk -F "-" '{ for (i=1; i<NF; i++) printf $i"-"}')
lastPart=$(echo "$projectBasename" | awk -F "-" '{ print $NF }')
if [[ ${lastPart:0:1} =~ ^[0-9] ]]
then
versionPath=$lastPart
namePath=${firstParts%?}
else
versionPath=""
namePath=$projectBasename
fi
echog "Search for information via ${bold}Path${TOA}"
logVersion "$versionPath"
if [ "$version" == "" ]; then version=$versionPath; fi
logName "$namePath"
if [ "$name" == "" ]; then name=$namePath; fi
# Set standard values if nothing
if [ "$version" == "" ] || [[ ${version:0:1} =~ ^[^0-9] ]]
then
version="$(date +%Y%m%d)"
fi
if [ "$sourceHtmlUrl" == "" ]
then
sourceHtmlUrl="$source"
fi
then
name=$projectBasename
fi
then
fi
requires=$(echo "$requires" | tr ',' '\n' | sed 's/\([<<>>==].*\)/(\1)/' | sed -e $'s/((/(/g' | sed -e $'s/))/)/g')
requires=$(echo "$requires" | tr '\n' ',' | sed -e 's/^,*//' -e 's/,*$//')
then
echo
echog "Install with ${green}checkinstall ... python setup.py install${TOA}"
sudo checkinstall --spec foo --maintainer \""$maintainer"\" --pkglicense \""$license"\" --pkgname \""$name"\" --pkgrelease \""$release"\" --pkgversion \""$version"\" --pkgsource \""$sourceHtmlUrl"\" --pkggroup \""$group"\" --requires \""$requires"\" --pkgarch \""$architecture"\" $(if [ "$checkinstallParam" != "" ]; then echo "$checkinstallParam"; fi) python setup.py install
else
echo
echog "Install with ${green}checkinstall ...${TOA}"
fi
