I installed Ubuntu 14.04.1 LTS on machine and have upgraded its kernel version to 4.2 with the following command:
sudo apt-get install linux-generic-lts-wily
I was a bit confused about kernel version and release name. Some software provides binaries for different releases: Trusty, Utopic, Vivid, Wily, ...
In this case, should I download a binary for Trusty or that for a newer release name as far as the software provides?
Jeon
  • 397
Ubuntu releases and the kernel versions are independent from each other.
Open a terminal and check the Ubuntu release version with this command :
lsb_release -a
The output shows something like :
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 15.10
Release:    15.10
Codename:   wily
Open a terminal and check the running kernel version with this command :
uname -r
4.2.0-22-generic
This was a PC running Ubuntu 15.10 - here is a PC running Ubuntu 14.04 :
If you opt into the hardware enablement stack for Ubuntu 14.04 (Trusty),
the outputs will show that the release still is 14.04 and the kernel is 3.19.
lsb_release -a
Description:    Ubuntu 14.04.3 LTS
Release:    14.04
Codename:   trusty
uname -r
3.19.0-42-generic
cl-netbox
  • 31,491
Upgrading your LTS release to a newer kernel line does not change the release name.
So you still have Ubuntu 14.04 trusty.
See about HWE
LTS releases allow to install kernels from non-LTS main releases.
linux-generic-lts-wily installs the kernel from 15.10 "wily" release. It will be default in Ubuntu 14.04.4.
This may be a bit confusing.
Pilot6
  • 92,041
