Good day to all!
I've been trying to use Empathy for Facebook chat for quite some time now but whenever I try to enable it, I get the "Applications can no longer access your Facebook online account blah, blah, blah..." and so I tried going to Online Accounts and then grant access. But whenever I click the button to grant access, it reverts back to "off" after maybe three seconds. What's happening and how can I solve this?
P.S. I already tried using Pidgin but I still get the same error. Sometimes I get the "authorization failed" error as well.
Also, I can log into my FB account using my web browser.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
A note upfront: It appears that Empathy doesn't support Facebook's messaging service, but Pidgin, a similar multi-messaging client based on the same library libpurple, does with a plug-in as described below.
The purple-facebook plugin is a replacement for the builtin Facebook XMPP plugin. Facebook is in the process of shutting down their XMPP service, which will inevitably break existing support.
(Source)
The following instructions are written for Pidgin and while they should work for the same for Empathy in theory (since they're both based on libpurple), people report that Empathy doesn't accept this plug-in for some reason.
To install purple-facebook in Ubuntu, Linux Mint and derivatives, you can use its official repository. To add the repository and install the plugin, use the following commands:
sudo add-apt-repository "deb http://download.opensuse.org/repositories/home:/jgeboski/xUbuntu_$(lsb_release -rs)/ /"
wget -O- 'https://jgeboski.github.io/obs.key' | sudo apt-key add -
sudo apt-get update
sudo apt-get install purple-facebook
If you don’t want to add the PPA, you can download the DEB from HERE (but you won’t receive any updates unless you add the repository). Or, grab the source and build it yourself. […]
Once installed, add a new account in Pidgin (Accounts > Manage Accounts > Add) and in the Protocol dropdown, select “Facebook” (important: NOT “Facebook (XMPP)”):
Pidgin Facebook I should also mention that in the username field, you can enter either your emil, your Facebook username or phone number associated with your Facebook account.
(Source with some modifications)
As of October 18, 2015, jgeboski's GSoC work was merged into the mainline Pidgin project. It will appear in the next major release of Pidgin.
This means, future libpurple versions in Ubuntu (and probably earlier in the Pidgin PPA) will include purple-facebook and supersede the above procedure.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
If I remember correctly - Facebook changed their API, which effectively prevented several packages from accessing your account and utilizing the API options - such as chat.
You can find more information with a simple Google search, for example: http://www.omgubuntu.co.uk/2015/04/facebook-chat-api-empathy-pidgin-stop-working
Last I heard, Pidgin and Empathy teams are working on a solution, I wish them the best of luck too.
  1. I follow the steps for installing The purple-facebook plugin for Pidgin.
  2. I install Pidgin.
  3. Created facebook account in Pidgin.
  4. In Empathy, import the facebook account from Pidgin. 5- Removed Pidgin software after facebook account imported.
And its working
TiloBunt
  • 2,315
