I'm getting this, do you know of a workaround:
 ubuntu-desktop
Error in function:
SystemError: E:Sub-process /usr/bin/dpkg returned an error code (1)
Error in sys.excepthook:
Traceback (most recent call last):
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 102, in apport_excepthook
    pr.add_proc_info(extraenv=['PYTHONPATH', 'PYTHONHOME'])
  File "/usr/lib/python3/dist-packages/apport/report.py", line 525, in add_proc_info
    raise ValueError('%s does not exist' % self['ExecutablePath'])
ValueError: /usr/bin/python3.4 (deleted) does not exist
Original exception was:
Could not install the upgrades
The upgrade has aborted. Your system could be in an unusable state. A
recovery will run now (dpkg --configure -a).
dpkg: dependency problems prevent configuration of ubuntu-desktop:
 ubuntu-desktop depends on ubuntu-session; however:
  Package ubuntu-session is not installed.
 ubuntu-desktop depends on unity-control-center; however:
  Package unity-control-center is not installed.
 ubuntu-desktop depends on unity-settings-daemon; however:
  Package unity-settings-daemon is not installed.
dpkg: error processing package ubuntu-desktop (--configure):
 dependency problems - leaving unconfigured
 ubuntu-desktop
Upgrade complete
The upgrade has completed but there were errors during the upgrade
process.
Gabor
  • 268
  • 18
So this prevented me from logging in to X after the upgrade because obviously ubuntu-desktop's dependencies like compiz were broken.
I fixed it by going to a plain text shell (Ctrl+Alt+F1) and then following this solution with a small tweak:
sudo vi /etc/apt/apt.conf
# add this line:   APT::Default-Release "vivid";
sudo apt-get -t vivid install apt/vivid
sudo apt-get update
sudo apt-get dist-upgrade
Gabor
  • 268
  • 18
According to How can I fix E: Sub-process /usr/bin/dpkg returned an error code (2)?
Try to follow this steps:
Ive Tried this from a german link:
Firstable: Downlad and start this file from the link below available.ksh
https://media-cdn.ubuntu-de.org/forum/attachments/10/04/7312538-available.ksh
Then
   sudo apt-get update && sudo apt-get dist-upgrade
   sudo dpkg --clear-avail
then again:
The where i had the information.
https://forum.ubuntuusers.de/topic/dpkg-fehler-bei-aktualisierung/
Hope it help
