I want to develop some application for the Ubuntu platform. But I don't know C++. I can learn QML very easily. The problem is that the logic or process behind the scene in an application seems to use C++. So I thought maybe I should learn Go (another reasons are also there), because it is not as vast as C++, and it can be directly used in QML.
I want to use the standard Ubuntu SDK API in my application. How can I do that using Go? How do I proceed?
You most certainly can: Here's a template with a short tutorial: https://github.com/nikwen/ubuntu-go-qml-template
Or if you want to create scopes, check out: https://developer.ubuntu.com/en/phone/scopes/tutorials/developing-scopes-go/
