I have encrypted my id_rsa with a password. I think Ubuntu has a keyring system which prevents me from inputting password every time I have to use id_rsa, like git push. Sometimes I don't need to type in the password, sometimes I do.
When I execute
$ ssh-add -l
Could not open a connection to your authentication agent.
$ gnome-keyring import ~/.ssh/id_rsa
WARNING: gnome-keyring:: couldn't connect to: /run/user/1000/keyring-wUoO5j/pkcs11: Connection refused
p11-kit: gnome-keyring: module failed to initialize, skipping: An error occurred on the device
gnome-keyring: couldn't find any place to import files
$ echo $SSH_AUTH_SOCK
/run/user/1000/keyring-wUoO5j/ssh
$ echo $SSH_AGENT_PID
<empty>
In seahorse, the key is listed in openssh keys
Does any body has the same problem? Or how to solve this?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
dspjm
  • 280
I recently had a similar issue (I'm using ElementaryOS), where I had to enter my key's password every time I used it in the terminal. It used to ask me for the password via the GUI and kept that in memory for a while, but this somehow stopped working.
I tried many of the suggestions found by Googling this (eg. adjust deamon config via gconf-settings, checked startup applications, add to .bashrc, install keychain, ..) but to no avail.
I did find this article on Cup of Linux which suggested checking the pam.d settings in /etc/pam.d/. Since my configuration was definitely different as in the article, I search for pam_gnome_keyring and commented all occurences in all files of the lines
auth    optional        pam_gnome_keyring.so
session optional        pam_gnome_keyring.so auto_start
After a reboot / relogin, I was finally asked by the GUI again for the password..
grep before changes:
:~$ grep -r pam_gnome_keyring /etc/pam.d/
/etc/pam.d/common-password:password optional    pam_gnome_keyring.so
/etc/pam.d/lightdm-greeter:auth    optional        pam_gnome_keyring.so
/etc/pam.d/lightdm-greeter:session optional        pam_gnome_keyring.so auto_start
/etc/pam.d/lightdm:auth    optional        pam_gnome_keyring.so
/etc/pam.d/lightdm:session optional        pam_gnome_keyring.so auto_start
grep after changes (note the # in the last 4 lines):
/etc/pam.d/lightdm-greeter:#auth    optional        pam_gnome_keyring.so
/etc/pam.d/lightdm-greeter:#session optional        pam_gnome_keyring.so auto_start
/etc/pam.d/lightdm:#auth    optional        pam_gnome_keyring.so
/etc/pam.d/lightdm:#session optional        pam_gnome_keyring.so auto_start
4levels
  • 187
Probably the Gnome services such as gnome-keyring-daemon and gnome-settings-daemon are not running when you are logged in.
AFAIR you can change this: choose settings > settings manager > session and startup > advanced and enable Gnome services
Another way to avoid typing in your password every time, is to use the following commands once after system startup in a terminal
ssh-agent
ssh-add <add path if not standard key>
you will be prompted for your password to your key and the agent will store it until next reboot.
HTH,
s1mmel
s1mmel
  • 2,124
