I got a notification that I need to install updates, and I clicked yes, but since then I am getting this stop sign on the top right corner because of unmet dependencies. when i run:
sudo apt-get install -f
I get bunch of packages to be removed and then:
The following extra packages will be installed:
collada-dom2.4-sp-dev
The following NEW packages will be installed:
When I click yes:
Selecting previously unselected package collada-dom2.4-sp-dev.
(Reading database ... 306874 files and directories currently installed.)
Preparing to unpack .../collada-dom2.4-sp-dev_2.4.4.1-ubuntu1~trusty1_amd64.deb ...
Unpacking collada-dom2.4-sp-dev (2.4.4.1-ubuntu1~trusty1) ...
dpkg: error processing archive /var/cache/apt/archives/collada-dom2.4-sp-dev_2.4.4.1-ubuntu1~trusty1_amd64.deb (--unpack):
trying to overwrite '/usr/lib/cmake/collada_dom-2.4/collada_dom-config.cmake', which is also in package collada-dom2.4-dp-dev 2.4.4.0-ubuntu1~trusty1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
when I run sudo apt-get autoremove I get:
You might want to run 'apt-get -f install' to correct these.
collada-dom-dev : Depends: collada-dom2.4-sp-dev but it is not installed
E: Unmet dependencies. Try using -f.
Any help would be appreciated, thank you.
