Many folks have been asking to remove the top round corners on windows in gnome 3. I want to extend it to the bottom corners as well. Wondering if it is possible? There is a similar question asked before but it wasn't intended for the default adwaita theme which gnome 3 uses. I found the file /usr/share/gnome-shell/theme/gnome-shell.css which contains some radius stuff but I am not good at it. Wondering if someone knows how to round the bottom corners.
Asked
Active
Viewed 5,134 times
Organic Marble
- 24,696
user2438113
- 11
Here's how you should proceed:
- Look for
border-radiusproperty.
Case I: If there is just a single value assigned to it, like border-radius: 18px;, then it means that the borders will be rounded from all the 4 directions (Top, Right, Bottom, Left) equally (18px in this case).
Case II: Shorthand Property: If there are multiple values, like border-radius: 18px 0px 0px 18px;, then remember the order (Top, Right, Bottom, Left). This means that the 3d value (0px in this case), represents the bottom radius. Set it to a non-zero value!
Note: It should not be very hard finding border-radius with shorthand notation. For example, my own gnome-shell.css has only 9 occurences where the border-radius shorthand property (2nd case) is used!
Hope it helps.
Avijit Gupta
- 101
