I have a Dell Inspiron i7559, which has an unfortunate combination of a NVidia GTX960M and an Intel 3165 AC card. All proprietary NVidia drivers only seem to work on the 3.x kernels, whereas the official iwlwifi firmware for this card is only available on kernel 4.1+: so currently I am on 3.19 because I need the GPU and I am using a USB wireless module.
So, I am wondering if there are any options for making the internal card usable in kernel 3.19. Ubuntu detects it as an Intel 3165 card. For more information:
$ lshw -C network
 *-network UNCLAIMED
   description: Network controller
   product: Intel Corporation
   vendor: Intel Corporation
   physical id: 0
   bus info: pci@0000:05:00.0
   version: 79
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress cap_list
   configuration: latency=0
   resources: memory:df200000-df201fff
$ lspci
05:00.0 Network controller: Intel Corporation Device 3165 (rev 79)
Thanks for your time!
bain
  • 12,200
With a working internet connection by ethernet, tethered or whatever means possible, open a terminal and do
sudo apt-get update
sudo apt-get install linux-headers-generic build-essential
wget https://www.kernel.org/pub/linux/kernel/projects/backports/2015/11/20/backports-20151120.tar.gz
tar -zxvf backports-20151120.tar.gz
cd backports-20151120
make defconfig-iwlwifi
make
sudo make install
Now we need the latest firmware. First, verify that you have these two files; iwlwifi-7265D-13.ucode and iwlwifi-7265-13.ucode:
ls /lib/firmware | grep 7265
If so, we are going to make copies but rename them:
cd /lib/firmware
sudo cp iwlwifi-7265D-13.ucode  iwlwifi-3165-9.ucode
sudo cp iwlwifi-7265-13.ucode  iwlwifi-3165-13.ucode
Reboot. Your wireless should be working.
You will need to recompile every time Update Manager installs a later kernel, known as linux-image. After the requested reboot, recompile:
make clean
make
sudo make install
Please retain the file and these instructions for that time.
chili555
  • 61,330
in case you are not able to find out where to get these files, please get it from the git repository:
git clone https://github.com/OpenELEC/iwlwifi-firmware.git
This solution worked for me temporarily. Permanent fix is to upgrade to kernel 4.1 as mentioned by Intel also(they certify that it works with 4.1 kernel)
Ashu
  • 4,004
Your post put me on the right track but didn't work. Instead of 7265-13 to make 3165-13 I needed 7265-12 to make 3165-12. Got it right reading budi5 post here.
  1. Downloaded the ucode for my Intel wifi device (3165) with 3.19+ kernel from here.
    cd ~/Downloads
    wget -c https://wireless.wiki.kernel.org/_media/en/users/drivers/iwlwifi-7265-ucode-25.17.12.0.tgz
  2. Renamed and copied the downloaded ucode files into /lib/firmware
    sudo cp ~/Downloads/iwlwifi-7265D-12.ucode /lib/firmware/iwlwifi-3165-9.ucode
    sudo cp ~/Downloads/iwlwifi-7265-12.ucode /lib/firmware/iwlwifi-3165-12.ucode
  3. Rebooted
    sud reboot
