-1
Is it possible for me to take a windows iso, and create a bootable USB stick while in ubuntu? There are loads of ways to do that on windows, but not from any linux-based os. Any information helps! Thanks.
EDIT: The version of windows can be wither windows 7, 8.1, or 10
marc.soda
  • 252
Download wine from ubuntu soft ware center and download this http://www.isotousb.com/ Open with wine select USB and burn the iso the USB should be in FAT32 format
You can open disks and select your pendrive choose from menu recovery disk image and select that iso and click restore
or you can use in terminal that command
sudo dd bs=4M if=[your iso] of=/dev/sd[that 1 letter]
