I have my computer set up to use the same home folder / user profile for Linux and Windows. As a consequence I have files like NTUSER.DAT that are hidden on Windows showing up when I ls and in my file manager. Is there any way to make Linux hide the hidden files?
Asked
Active
Viewed 7,010 times
12
21
Add the files you want to hide to a file named .hidden with 1 file per line inside the directory those files are. Somehing like ls {files} >.hidden will work to quickly do this.
You can hide files looking from Windows with
C:\>attrib +h D:\*.hidden /S(this will hide the.hiddenfile from the previous method). The directory I assumed D:.You can hide these files from
lson Linux by adding this into your~./bashrc:ls () { if [ -f .hidden ]; then declare GLOBIGNORE="$GLOBIGNORE:.*:$(tr '\n' ':' < .hidden)" ls "$@" fi }This will hide the files when using
lsandlsonly. It also assumes you do not already have an alias forls.ls -lwill still show them but that is just another alias.
The last command I found on superuser. Please upvote that answer ;)
