I've been searching for hours now, can't figure this one out.
I am trying to make the following happen:
Client: remmina + ssh tunnel
Server: Lubuntu + openssh server (public key authentication) + vino server over ssh tunnel ONLY + allow client to only open 1 port (vnc port)
So far I can connect to my server apparently in both ways (with ssh tunnel and without it), which is unacceptable.
Running vino-preferences GUI doesn't help me much :s
So my question basically is:
  • "How do I block any port opening on server and only single SSH port (22) and allow client to tunnel VNC over SSH via specific port (If it makes sense)?"
  • No other type of VNC connection should be allowed
P.S. I plan to forward port 22 on router to my server and only allow SSH connections.
GogromaT
  • 143
AFAIK the vino-preferences GUI does not include it, but I believe the parameter you are looking for is network-interface
gsettings get org.gnome.Vino network-interface
If unset (i.e. the above command returns the empty string, '') then vino-server listens on all available interfaces, whereas if set to lo
gsettings set org.gnome.Vino network-interface 'lo'
then it will listen only on the lo (localhost) interface.
You could also use the GUI dconf-editor, where the parameter is listed under the org -> gnome -> desktop -> remote-access item.
You can confirm that the server is listening on the desired interface using netstat e.g. the default is
$ sudo netstat -nlp | grep ':5900'
tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      10927/vino-server
tcp6       0      0 :::5900                 :::*                    LISTEN      10927/vino-server
(listening on all available interfaces); then after
$ gsettings set org.gnome.Vino network-interface 'lo'
you should see that it is only listening on the localhost interface(s):
tcp        0      0 127.0.0.1:5900          0.0.0.0:*               LISTEN      10927/vino-server
tcp6       0      0 ::1:5900                :::*                    LISTEN      10927/vino-server
Alternatively (or additionally), you could use iptables or ufw to close the port - by default, it is port 5900 + display number.
steeldriver
  • 142,475
