I try sudo apt-get install libpq-dev and I got this error
Reading package lists... Done
Building dependency tree
 libpq-dev : Depends: libssl-dev but it is not going to be installed
             Depends: krb5-multidev but it is not going to be installed
             Depends: comerr-dev but it is not going to be installed
I also run this command apt-cache policy libpq-dev libssl-dev krb5-multidev comerr-dev and this is the result
libpq-dev:
  Installed: (none)
  Candidate: 9.3.4-1
  Version table:
     9.3.4-1 0
    500 http://sd.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
libssl-dev:
  Installed: (none)
  Candidate: 1.0.1f-1ubuntu2
  Version table:
     1.0.1f-1ubuntu2 0
krb5-multidev:
  Installed: (none)
  Candidate: 1.12+dfsg-2ubuntu4
  Version table:
     1.12+dfsg-2ubuntu4 0
comerr-dev:
  Installed: (none)
  Candidate: 2.1-1.42.9-3ubuntu1
  Version table:
     2.1-1.42.9-3ubuntu1 0
output of sudo apt-get install libssl-dev krb5-multidev comerr-dev
 comerr-dev : Depends: libcomerr2 (= 1.42.9-3ubuntu1) but 1.42.9-3ubuntu1.2 is to be installed
 krb5-multidev : Depends: libkrb5-3 (= 1.12+dfsg-2ubuntu4) but 1.12+dfsg-2ubuntu5.1 is to be installed
                 Depends: libk5crypto3 (= 1.12+dfsg-2ubuntu4) but 1.12+dfsg-2ubuntu5.1 is to be installed
                 Depends: libgssapi-krb5-2 (= 1.12+dfsg-2ubuntu4) but 1.12+dfsg-2ubuntu5.1 is to be installed
 libssl-dev : Depends: libssl1.0.0 (= 1.0.1f-1ubuntu2) but 1.0.1f-1ubuntu2.15 is to be installed
              Recommends: libssl-doc but it is not going to be installed
what i can do to fix this?
Your sources are very outdated, ex. of current versions,
libpq-dev - 9.3.10-0ubuntu0.14.04
libssl-dev - 1.0.1f-1ubuntu2.16
krb5-multidev - 1.12+dfsg-2ubuntu5.2
comerr-dev - 2.1-1.42.9-3ubuntu1.3
Open Software & Updates, make sure that both trusty-security & trusty-updates are enabled under the Updates tab, then reload your sources & see if you get the current versions. If both were already enabled then open a terminal & run sudo apt-get update, then check for current versions.
If that doesn't help then again open Software & Updates & on main page switch to a different mirror in the Download from: section, reload sources, ect.
A.B.
  • 92,125
doug
  • 17,212
As I can see here and in your question, you have some (manually?) installed packages which conflict with the packages in the Ubuntu standard repositories. The packages that you want to install, need exactly the required versions of the dependencies.
Run the commands below:
sudo apt-get update
sudo apt-get install libssl1.0.0=1.0.1f-1ubuntu2 ibcomerr2=1.42.9-3ubuntu1
to downgrade each of them.
For the other packages you have to enable trusty-security and trusty-updates (with a little script taken from here). This packages contains a higher version than the installed version.
sudo apt-get install git
git clone https://github.com/kos0/addRemoveDistribution.git
cd addRemoveDistribution
sudo ./enableDisableDistribution.pl enable security
sudo ./enableDisableDistribution.pl enable updates
After that
sudo apt-get update
A.B.
  • 92,125
