Today I tried to upgrade to Ubuntu 15.04 from 14.04. I did the folowing commands:
sudo apt-get update sudo apt-get upgrade sudo do-release-upgrade
But during the last command, after lots of get messages I get the following error:
Error authenticating some packages. Continue?
It was not possible to authenticate some packages. This may be a
transient network problem. You may want to try again later. See below
for a list of unauthenticated packages.
gettext
lib32stdc++6
libatomic1
libfftw3-single3
libgfortran3
libgomp1
libitm1
libquadmath0
libstdc++6
libtsan0
onboard
Restoring original system state
Aborting
How can I upgrade without these errors? I have tried similar questions but with no success.
Upgrading from 14.04 to 15.04 directly is not supported. You'd have to do 14.04->14.10->15.04, which will not work, as 14.10 has reached End of Life. Last but not least, 15.04 itself will reach EoL is January 2016, which makes upgrading unworthy.
I'd recommend staying on 14.04, and upgrading to 16.04 in due course (in summer 2016).
mikewhatever
  • 33,013
If you really want to upgrade to 15.04, you will have to download the 15.04 image from here: http://releases.ubuntu.com/15.04/
Then you will need to create a bootable USB drive with that file, and boot from it. When the installer is loaded, you will be given an option to upgrade the existing Ubuntu installation.
That being said, you should still back up all your files just in case, and it's probably easier if you wait for 16.04, unless you absolutely need 15.04 for something.
