I have an Ubuntu 14.04 LTS "Desktop" with GitLab. The system runs in a virtual machine on a Windows Server 2012 R2.
The machine runs daily automatic updates for "Important security updates", "Recommended updates" and "Unsupported updates". Not for "Pre-release updates".
Today I logged in the system, ran "sudo apt-get update" and it couldn't finish because some process is using dpkg.
I've ran "sudo apt-get upgrade" and it updated but hanged at:
Found linux image: /boot/vmlinuz-3.19.0-39-generic
Found initrd image: /boot/initrd.img.3.19.0-39-generic
Found linux image: /boot/vmlinuz-3.19.0-37-generic
Found initrd image: /boot/initrd.img.3.19.0-37-generic
Found linux image: /boot/vmlinuz-3.19.0-33-generic
Found initrd image: /boot/initrd.img.3.19.0-33-generic
Found linux image: /boot/vmlinuz-3.19.0-32-generic
Found initrd image: /boot/initrd.img.3.19.0-32-generic
Found linux image: /boot/vmlinuz-3.19.0-31-generic
Found initrd image: /boot/initrd.img.3.19.0-31-generic
I rebooted and hanged again at the same point for an "sudo apt-get upgrade".
Then I tried to clean the unused kernels. I ran:
uname -r
and got:
3.19.0-39-generic
So I removed 3.19.0-31, 3.19.0-32 and 3.19.0-33:
sudo rm /boot/initrd.img.3.19.0-31-generic
sudo rm /boot/initrd.img.3.19.0-32-generic
sudo rm /boot/initrd.img.3.19.0-33-generic
sudo rm /boot/vmlinuz-3.19.0-31-generic
sudo rm /boot/vmlinuz-3.19.0-32-generic
sudo rm /boot/vmlinuz-3.19.0-33-generic
Then, I tried to purge:
sudo apt-get purge linux-image-3.19.0-31-generic linux-image-3.19.0-32-generic linux-image-3.19.0-33-generic
But the process hanged also.
Then, I could "update" but the "upgrade" failed at:
At some update/upgrade, it suggested me to run dpkg --configure -a but it also failed at the same point above.
Also, when I reboot, the system gets stuck at the "dots screen". I have to "power off" the virtual machine and restart it to get into it.
After some apt-get update, apt-get upgrade, dpkg --configure -a and reboots I'm not sure how, but everything ran fine again.
Now I'm again with the same problems:
  1. When I run apt-get update, apt-get upgrade I get:
    E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
  2. When I run sudo dpkg --configure -a it hangs after:
    Found linux image: /boot/vmlinuz-3.19.0-42-generic
    Found initrd image: /boot/initrd.img-3.19.0-42-generic
    Found initrd image: /boot/initrd.img-3.19.0-39-generic
  3. The system also hangs at the "dots screen" when I reboot
I'm quite noob with linux. Can anybody put some light here?
Yeray
  • 203
Temporally fixed it!
After some reboots and some attempts to apt-get update, apt-get upgrade, apt-get dist-upgrade and dpkg --configure -a, the last command finally ended successfully and the rest of commands started to also run with success.
Updated to 3.19.0-42-generic kernel during the process.
So I'm not sure what exactly caused it, neither what exactly fixed it, but anyway... :)
Yeray
  • 203
It looks as through at some point you upgraded your kernel and it did not fully take I would make sure the kernel is correct by running:
sudo apt-get dist-upgrade
Then update and upgrade:
sudo apt-get update && sudo apt-get upgrade
Next you can check all pakages are correct by running
sudo apt-get -f install
Wtower
  • 467
DnrDevil
  • 1,478
I had a similar problem twice and I have noticed that it happens everytime my system wants to upgrade to a new Kernel. The steps below seem to work for me all the time;
  1. Boot into the recovery mode of your newest kernel versions.
  2. Log-in to the system as root from the drop-down menu.
  3. Edit the /etc/resolv.conf file using a text editor, I normally use vi, i.e. vi /etc/resolv.conf and put in the contents below and save file;
nameserver 208.67.222.220
nameserver 208.67.222.222
  1. After the above step, Ctrl+D (exit) back into the recovery mode menu and click on networking to enable network/internet connection.
  2. Next, click on the dpkg item to fix broken packages.
That's it, after the reboot your system should have the right kernel install and broken packages fixed/removed.
That’s just to configure a DNS server in order to resolve IP address mapping.
You can even use the public google server
8.8.8.8 and 8.8.4.4
