I'm trying to mount a unionfs file system in fstab (as one of the steps in this guide), with the following line:
unionfs /usr unionfs nodev,noatime,dirs=/.filesystems/usr/overlay=ro:/usr=rw 0 0
I've installed the package unionfs-fuse and added unionfs to /etc/modules, but when trying to mount -a I still get an error saying
mount: unknown file system type: unionfs
What am I doing wrong here?
Sergey
  • 44,353
Tomas Aschan
  • 2,952
I've solved (or rather worked around) this, by not using unionfs and instead using aufs - another union file system.
Install the AUFS package and its kernel module from linux-image-extra-virtual:
sudo apt-get install aufs-tools linux-image-extra-virtual
The corresponding row in my fstab now looks like this:
usr    /usr    aufs    udba=reval,br:/.filesystems/usr/rw:/.filesystems/usr/ro    0   0
The squashfs is mounted at /.filesystems/usr/ro in the previous line, making this working as a substitute for the troubling steps in the guide I referred to in the OP.
Kaz Wolfe
  • 34,680
Tomas Aschan
  • 2,952
Create underlying squashfs on loop device through the terminal:
/.filesystems/usr/usr.sqfs /usr squashfs ro,loop,nodev 0 0
Create aufs virtual filesystem that allows you to write on it:
aufs /usr aufs nodev,noatime,dirs=/.filesystems/usr/overlay=rw:/usr=ro 0 0
Also consider adjusting /etc/sysctl.conf (!) if shutting down your PC takes longer than it should. Decrease the swap - swap turned off below
vm.swappiness = 0
m.dirty_background_ratio = 20
vm.dirty_expire_centisecs = 0
vm.dirty_ratio = 80
vm.dirty_writeback_centisecs = 0
efthialex
  • 3,941
