13
There are many ways to mount an SMB share in Ubuntu. For example:
  • as root, you can use mount.cifs:
    mount -t cifs -o user=username //servername/sharename/ /mnt
  • you can use smbnetfs as described here
However, I would like to use gvfs. When logging in using ssh. I tried the following without a success:
dbus-launch bash
gvfs-mount smb://servername/sharename/
This works... kind of. When I run
gvfs-mount -l
I get the following:
Mount(0): sharename on servername -> smb://servername/sharename/
  Type: GDaemonMount
So, the mount seems to work. However, there is no file system mount point, whereas when I mount it using Nautilus, I get a mountpoint in /run/user/1000/gvfs/, which I can then access using command line.
What should I do to get a mount point with gvfs which I can access with the command line?
January
  • 37,208
At least with Ubuntu 18.04, the following works:
$ gio mount smb://<server>/<share>
Password required for share <share> on <server>
User [<user>]:
Domain [<workgroup>]:
Password:
The mount points are located in /run/user/<uid>/gvfs/ (idem $XDG_RUNTIME_DIR/gvfs).
Pablo Bianchi
  • 17,371
The mount point should be in ~/.gvfs. At least by me it was there with this name: smb-share\:domain\=WORKGROUP\,server\=192.168.0.186\,share\=asmedia-hdd\,user\=root/. If you still cannot find it, you can try sudo find / -name sharename -type d. Maybe it finds the directory somewhere else. Another possible location is /run/user/1000/gvfs.
inf3rno
  • 262
  • 14
