I'm on Xubuntu (Ubuntu 14.04), kernel 3.19.
None of the network related interfaces give me any indication that my computer is capable of detecting or connecting to WiFi networks.
This is an HP ENVY - 15t Slim Quad Laptop Product number: T1P54AV, the specs they provided me with are:
  • HP TrueVision HD Webcam with Dual Digital Microphone
  • 8GB DDR3L System Memory (1 Dimm)
  • 1TB 5400 rpm Hard Drive
  • 6-cell 47WHr Lithium-ion Battery
  • Backlit Keyboard
  • 6th Gen Intel(R) Core(TM) i7-6700HQ Quad Core Processor + Intel(R) HD Graphics 530
  • Intel 802.11ac WLAN and Bluetooth(R) [1x1]
  • No DVD or CD Drive
  • 15.6-inch diagonal Full HD WLED-backlit IPS Display (1920x1080)
lspci -nn gives me:
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
02:00.0  Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device [10ec:522a] (rev 01)
08:00.0 Network controller [0280]: Intel Corporation Device [8086:3165] (rev 81)
ifconfig does not give me any connection other then Ethernet or lo:
eth0
lo
iwconfig similarly:
eth0      no wireless extensions.
lo        no wireless extensions.
The rfkill list output is:
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
lshw -C network yields:
*-network
description: Ethernet interface product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:01:00.0 logical name: eth0 version: 0c serial: dc:4a:3e:62:f2:83 size: 100Mbit/s capacity: 1Gbit/s width: 64 bits clock: 33MHz capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168g-2_0.0.1 02/06/13 ip=192.168.2.111 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s resources: irq:124 ioport:4000(size=256) memory:a3200000-a3200fff memory:a3000000-a3003fff *-network UNCLAIMED description: Network controller product: Intel Corporation vendor: Intel Corporation physical id: 0 bus info: pci@0000:08:00.0 version: 81 width: 64 bits clock: 33MHz capabilities: cap_list configuration: latency=0 resources: memory:a3100000-a3101fff
lspci -nnk | grep -iA2 net yields:
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c) Subsystem: Hewlett-Packard Company Device [103c:8154] Kernel driver in use: r8169
08:00.0 Network controller [0280]: Intel Corporation Device [8086:3165] (rev 81) Subsystem: Intel Corporation Device [8086:4010] Kernel driver in use: iwlwifi
I'm kind of lost here. I've tried several things including installing drivers backported to my kernel version but none of it changed the behaviour I've described above.
Something that I believe is of note is that I've ran archlinux on this machine before and it was able to detect my wireless card without problems during installation. I looked up the realtek wireless drivers it provides and attempted to install them from a package of backports (possibly incorrectly though and it didn't help)
Any help would be appreciated, I've been stuck here for a while.
You can use ndiswrapper. It allows you to install Windows drivers of wireless cards.
Before installing:
Type lshw -C network in a terminal. You can also try lspci -vvnn look for the wireless card. It looks like this in my terminal:
 *-network
       description: Wireless interface
       product: AR9485 Wireless Network Adapter
       vendor: Qualcomm Atheros
       physical id: 0
Installation
If you have wired access to internet:
sudo apt-get install ndisgtk
If you don't you can find the packages you'll need at http://packages.ubuntu.com. Here are the 3 packages you'll need:
  1. http://packages.ubuntu.com/trusty/ndiswrapper-common
  2. http://packages.ubuntu.com/trusty/ndiswrapper-utils-1.9
  3. http://packages.ubuntu.com/trusty/ndisgtk
Now you can download the Windows driver. You can find it on the manufacturer's website and install it with ndiswrapper.
You should also read this for more details
karel
  • 122,292
  • 133
  • 301
  • 332
albertoefg
  • 161
From your HP ENVY Manual page 11: press the F12 (or FnF12 depending on BIOS settings) to turn on WiFi... (Do this after the computer has fully booted)
Fabby
  • 35,017
