I use a video card Nvidia Geforce 210.
According to it's specs it can run :Maximum Digital Resolution 2560x1600 and Maximum VGA Resolution 2048x1536.
I use Ubuntu 14.04 LTS with NVIDIA-Linux-x86-340.96.run driver instaled and activated and the maximum resolution I get is 1360x768 that is to narrow and 1152x864 that is to wide on both of my monitors (used as expanded):
  1. Optiquest Q201wb 1680 x 1050
  2. Iiyama prolite e2200ws 1680 × 1050
Can you give me an advice on how to make my resolution 1680x1050 permanent(not only until first reboot)?
Whith nouveau display driver it's the same thing as is with Nvidia driver 304.131
PS. I saw [this similar post]Cant get full resolution on Second monitor with nvdia geforce 210 on 14.04) but I don't think it's the same problem.
Output from xrandr
    Screen 0: minimum 8 x 8, current 2304 x 864, maximum 8192 x 8192
DVI-I-0 connected primary 1152x864+1152+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768       60.0 +
   1360x768       60.0     59.8
   1152x864       60.0*
   800x600        72.2     60.3     56.2
   680x384        60.0     59.8
   640x480        59.9
   512x384        60.0
   400x300        72.2
   320x240        60.1
VGA-0 connected 1152x864+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768       60.0 +
   1360x768       60.0     59.8
   1152x864       60.0*
   680x384        60.0     59.8
   640x480        59.9
   512x384        60.0
   400x300        72.2
   320x240        60.1
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
I resolved my problem by seeking on the internet the horizontal and vertical refresh rate for my monitors:
1.Optiquest Q201wb 1680 x 1050
Horizontal refresh rate 30-80 Hz
Vertical refresh rate 55-75 Hz
2.Iiyama prolite e2200ws 1680 × 1050
Horizontal refresh rate 31-82 Hz
Vertical refresh rate 56-75 Hz
Then by using Torben Gundtofte-Bruun's tutorial from here How do I set the correct monitor resolution with Nvidia drivers for a monitor that does not send EDID? I've edited /etc/X11/xorg.conf file with
 sudo gedit /etc/X11/xorg.conf
and I entered the values 31-80 Hz for
HorizSync
and 56-75 Hz for
VertRefresh
in the
Section "Monitor"
part. The values from there were very different from the above.
After that , from Displays I could select the 16:10 ratio 1680x1050 resolution. I'm verry happy now. Thank you Torben Gundtofte-Bruun.
