I'd like to install libjbig-dev on Ubuntu 14.04 LTS. So I run
sudo apt-get install libjbig-dev
which returns
Reading package lists... Done
Building dependency tree
 libjbig-dev : Depends: libjbig0 (= 2.0-2ubuntu4) but 2.0-2ubuntu4.1 is to be installed
So I do
sudo apt-get install libjbig0
which returns
libjbig0 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Now what? How can I install libjbig-dev? Thanks.
