Versions are:
Ubuntu server version is 10.04
PHP version is 5.4.7
Mysql version is 5.1.69
Apache server version is 2.4.3
Now, I would like to update to Ubuntu 14.04 but no update PHP, Mysql and Apache. If I update, is there any compatibility issue?
Versions are:
Open terminal (by pressing Ctrl+Alt+T) and run this command:
sudo apt-get install tasksel
after finish run this command
sudo tasksel
then select lamp using space bar and go on the installing instructions.
If you already have them, do a dist-upgrade without touching those existing packages Exclude packages from `apt-get upgrade`
Please check this URL it will tell you how to do it and use very easy way
How To Set Up the Ubuntu 14.* Included X-Windows(xUbuntu) / MySql / PHP (Apache 2 ) In VMware
There shouldn't be a compatibility issue with Ubuntu 14.04. If you upgrade, your server software will be updated too. (If you specifically don't want to upgrade the server software, then don't upgrade Ubuntu because trying to use an older version of software with a newer Ubuntu version is always a fight against the package manager.)
