I want to install these packages to my Ubuntu server from USB as i have tried many thing by editing mirrors in /etc/apt/sources.list to install some packages for Ubuntu server 14.04 know I want to try installing them from USB so would any one guide me how should I?
sudo apt-get install git build-essential libacl1-dev libattr1-dev libblkid-dev libgnutls-dev libreadline-dev python-dev python-dnspython gdb pkg-config libpopt-dev libldap2-dev dnsutils libbsd-dev attr krb5-user docbook-xsl libcups2-dev libpam0g-dev ntp -y
hg8
  • 13,582
global
Assuming you have all those packages downloaded as .deb files (you did not say, if you don't have them you can get any packages from the Ubuntu repo here) on your USB, copy them to a folder we will call it packages and put it in /home, or you can just change to the USB if you know its path
mkdir packages
Put all your .debs in here and change to the directory
cd ~/packages
Then run
sudo dpkg -i *.deb
To install all .deb files in the folder, to resolve dependencies
sudo apt-get -f install
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
"dpkg -i yourpackage.deb" should do the job if I understand your question properly - once you have your USB memory stick mounted with the .deb files of your choice.
Jacek
  • 1,921
