I want to delay start an service on boot. Ubuntu Server 15.10
I've created the file /startup-tvheadend.sh (chmod +x)
#!/bin/bash
sleep 20 && service tvheadend start;
Then in crontab -e
@reboot /startup-tvheadend.sh
Running the script as sudo works but not when I reboot the computer. I've disabled the default auto start after installation.
kidkic@TvHeadEnd:~$ systemctl status tvheadend
● tvheadend.service - (null)
   Loaded: loaded (/etc/init.d/tvheadend)
   Active: inactive (dead)
     Docs: man:systemd-sysv-generator(8)
s3lph
  • 14,644
  • 60
  • 83
roady
  • 145
It's simpler to add a sleep to the systemd configuration file. For example, to delay the bind9 start, we can edit (On Ubuntu 16.04) /lib/systemd/system/bind9.service and add a ExecStartPre command. (See https://www.digitalocean.com/community/tutorials/understanding-systemd-units-and-unit-files )
[Service]
ExecStartPre=-/bin/sleep 5
EnvironmentFile=/etc/default/bind9
gerardw
  • 521
As you are using systemctl status tvheadend, I guess you should also use systemd's systemctl instead of upstart's service command to start this service:
#!/bin/bash
sleep 20 && systemctl start tvheadend;
s3lph
  • 14,644
  • 60
  • 83
