11
Specifically, I want to run
lsyncd lsyncd.lua
And
webpack --progress --color -w
Which are both long-running processes. I want to see the output from both, interlaced in my terminal. It doesn't matter if the results are a bit jumbled, I just like to see that they're doing what they're supposed to.
Also, I want it to kill both processes when I press Ctrl+C.
I'm trying
parallel ::: 'lsyncd lsyncd.lua' 'webpack --progress --color -w'
which seems to be working, but I can't see any output even though when I run those commands individually, they output something.
mpen
  • 2,236
6 Answers6
GNU Parallel defaults to postponing output until the job is finished. You can instead ask it to print output as soon there is a full line.
parallel  --lb ::: 'lsyncd lsyncd.lua' 'webpack --progress --color -w'
It avoids half-line mixing of the output:
parallel -j0 --lb 'echo {};echo -n {};sleep {};echo {}' ::: 1 3 2 4
Spend 20 minutes reading chapter 1+2 of GNU Parallel 2018 (online, printed). Your command line will love you for it.
Ole Tange
  • 1,742
Using parallel (in the moreutils package):
parallel -j 2 -- 'lsyncd lsyncd.lua' 'webpack --progress --color -w'
Since the parallel process runs in the foreground, hitting CTRL+C will terminate all the processes running on top of it at once.
  • -j: Use to limit the number of jobs that are run at the same time;
  • --: separates the options from the commands.
% parallel -j 2 -- 'while true; do echo foo; sleep 1; done' 'while true; do echo bar; sleep 1; done'
bar
foo
bar
foo
bar
foo
^C
kos
  • 41,268
Using GNU parallel
1. Output ordered by finishing time of each command
You could group your parallel executed commands by using parallel (install it with sudo apt install gnu_parallel) with the argument --group. This ensures, that the output of each command waits till the command has finished (avoids mixed output).
Example:
parallel --group 'echo -n {};sleep {};echo {}' ::: 1 3 2 4
Output:
11
22
33
44
From the manual (man parallel):
--group: Group output. Output from each job is grouped together and is
only printed when the command is finished.
2. Output ordered by the order of input parameters
Another option is to control the output by the order of input parameters by using the -k argument.
Example:
parallel -k 'echo -n {};sleep {};echo {}' ::: 1 3 2 4
Output:
11
33
22
44
--keep-order, -k: Keep sequence of output same as the order of input.
Normally the output of a job will be printed as soon as the job completes.
snukone
  • 121
& to the rescue. It launches the two processes in parallel.
lsyncd lsyncd.lua & webpack --progress --color -w
This will do the trick.
Didn't read the kill part. A ctrl+C here would only terminate the second one. The process preceding the & runs in the background although it outputs on the stdout.
The shortest way to terminate both processes is: 1. Type Ctrl+C once. It kills the foreground process. 2. Type fg and type Ctrl+C again. It brings the background process to foreground and kills it too.
HTH!
Donbhupi
  • 149
There is a light-weight way of doing it without installing anyting.
Step 1: Create a script file runner.sh
#!/bin/bash
lsyncd lsyncd.lua &
P1=$!
webpack --progress --color -w &
P2=$!
wait $P1 $P2
Step 2: Make it executable
chmod +x runner.sh
Step 3: Run it
./runner.sh
It works like cream
Explanation:
  1. some_command & means run some_command and put it in background
  2. lsyncd lsyncd.lua & means run lsyncd lsyncd.lua and put this process in background.
Note: this works with Debian based Linux distros like Ubuntu
shivampip
  • 521
You have more options. Run the first command and press Ctrl-Z. This puts the command to wait in the background. Now type bg and it will run in background. Now run the second command and press Ctrl-Z again. Type bg again and both programs will run in background.
Now you can type jobs and it will print which commands are running in background. Type fg <job number> to put program in foreground again. If you omit the job number it will put the last job in the foreground. When the job is in foreground you can stop it with Ctrl-C. I don't know how you would stop both with one Ctrl-C.
You can also add & at the end which puts it running in the background immediately without Ctrl-Z and bg. You can still bring it in foreground with fg.
nobody
  • 4,412
