I am considering the purchase of the new "Pine 64" computer.
This computer uses a MicroSD memory card for the operating system. I would be using Ubuntu for the operating system. The notes indicate it is compatible with Ubuntu as the operating system.
The FAQ says:
'With the microSD card inserted in the card slot, all files necessary for booting should be installed in a microSD card with FAT32 partition.'
My question is if a FAT32 partition is default or will I have to do something special when I install Ubuntu on the MicroSD card?
Thank you.
Download the latest ARM-HF image of Ubuntu
Use unetbootin to flash the image to your SD card if you are on Linux
Use Win32DiskImager if you are on Windows
Done :)
There's now better documentation. Go to http://wiki.pine64.org/index.php/Pine_A64_Software_Release#Linux_Image_Release
Download the image, and then you can flash using various tools.
https://www.raspberrypi.org/documentation/installation/installing-images/linux.md shows you how to use dd to flash.
pd12
  • 1,409
