I have bought an Epson L220 printer and would like to install the drivers onto my HP Laptop.
How do I get and install it on Ubuntu 14.04 LTS (amd64 architecture)?
You need to install the drivers for the printer. This can be found on the Epson website.
Please go to:
Epson L220 printer.Make sure you do this for all the files available in step 3 above.
Install the .deb package files with your favourite package manager, e. g. GDebi or Software Center (Ubuntu 16.04 or later only) or on the command-line:
sudo dpkg -i /path/to/pacakge.deb ...
sudo apt install -f
As a side note, the best way to find if a printer is compatible is to search OpenPrinting.org. I found the Epson L220 printer there, and saw that it was compatible. I then searched for the recommended driver on Google which pointed me to the Epson Linux Driver website.
Connect to internet, then add the printer in System Settings -> Printers.
The driver should be downloaded automatically.
If it does not, post a comment. I will tell you how to install it manually.
The steps to get this working on ubuntu are simple
epson-inkjet-printer-201401w-1.0.0-1lsb3.2.x86_64 file. cd into opt/epson-inkjet-printer-201401w/ppds/Epson/. .ppd file. Printers in your start menu.Add driver via ppd. Thats it.
