How can I expand the Boot partition on Ubuntu 14.04.2 as it keeps telling me I have very little space left on that partition and I don't want to uninstall any files as I don't know what is necessary and what isn't?
Gerry
You probably have loads of old kernels installed. You can remove some of them as follows:
First check your current kernel (you definitely do not want to remove that one)
uname -r
Then check which are installed with:
sudo dpkg --list 'linux-image*' | grep ^ii
And to remove an old kernel:
sudo apt-get remove linux-image-OLDVERSION
Replace OLDVERSION with the version of the old kernel you want to remove
Afterwards update grub with:
sudo update-grub
(Updating grub is not strictly necessary since it should run automatically after you uninstall an old kernel, but it does no harm)
Byte Commander
  • 110,243
Limecat
  • 284
