After a fresh install of Kubuntu 15.10, my USB drive is automatically mounted as read-only in /media/usb0 instead of /media/<username>/
Mount output
$ sudo mount
/dev/sdb1 on /media/usb0 type vfat (rw,nodev,noexec,noatime,nodiratime,sync,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
Device is owned by root:
drwxr-xr-x  9 root root 4,0K janv.  1  1970 usb0/
dmesg | tail
I noticed errors=remount-ro at the end of the line of the mount result for the USB, so I decided to check dmesg for errors:
dmesg | tail
[64509.392669] sd 11:0:0:0: [sdb] Attached SCSI removable disk
[64509.698730] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
fsck
I run
$ sudo fsck.vfat -a /dev/sdb1
fsck.fat 3.0.28 (2015-05-16)
0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
 Automatically removing dirty bit.
There are differences between boot sector and its backup.
This is mostly harmless. Differences: (offset:original/backup)
  3:53/6d, 4:59/6b, 5:53/64, 6:4c/6f, 7:49/73, 8:4e/66, 9:55/73, 10:58/00
  Not automatically fixing this.
Reclaimed 123 unused clusters (503808 bytes) in 4 chains.
Performing changes.
/dev/sdb1: 3906 files, 500874/1974252 clusters
dmesg | tail again
dmesg | tail
[64990.154612]  sdb: sdb1
[64990.156582] sd 12:0:0:0: [sdb] Attached SCSI removable disk
No more errors, but still no write permissions.
Question
How do I automatically mount my USB a read-write?
  1. I remove usbmount (that I installed earlier) ;
  2. configure removable devices dialog (see KDE Plasma 5 Missing Removable Devices Option ):
    kcmshell4 device_automounter_kcm
  3. Starting 'Removable Device Automounter' from the Service Manager using
    kcmshell4 kcmkded
  4. unplug, replug and voilà!
