I have Apache running in Ubuntu 14.04. How do I disable and enable the SSL mode without a command? What about with a command?
As far as I know there is currently no way to disable SSL without command. With command, simply launch your terminal and enter
sudo a2dismod ssl
and restart apache2
sudo service apache2 restart
To do the opposite, use this command
sudo a2enmod ssl
and also restart apache2
- 4,023
For disabling SSL without a command you can manually edit the SSLEngine directive in your ssl configuration file (usually in /etc/apache2/sites-enabled/default-ssl.conf)
change:
SSLEngine on
to:
SSLEngine off
restart Apache. I guess that requires a command...
for Ubuntu 14.04 and before use: sudo service apache2 restart
for Ubuntu 16.04 and beyond use: sudo systemctl restart apache2.service
- 51
Only commands are available for disable and enable SSL
Locate your SSL Protocol Configuration on your Apache server with root permission. And type
grep -i -r "SSLProtocol" /etc/apache2
to disable
Type the following command to restart
apachectl -k restart
- 1,625
- 4
- 20
- 28
