I've already install the build-essential package but it doesn't work that's right i'm trying to compile a wireless driver i'm trying to use aircrack-ng so i need to patch the driver of my wireless adapter it's supposed to work typing the followings lines tar xfj rt73-k2wrlz-1.3.0.tar.bz2 cd rt73-k2wrlz-1.3.0/Module make make install
cristian@Cristian-pc:~$ sudo su
[sudo] password for cristian:
root@Cristian-pc:/home/cristian# cd Downloads
root@Cristian-pc:/home/cristian/Downloads# cd rt73-k2wrlz-3.0.3/Module
root@Cristian-pc:/home/cristian/Downloads/rt73-k2wrlz-3.0.3/Module# make
make[1]: Entering directory `/usr/src/linux-headers-3.0.0-12-generic'
  Building modules, stage 2.
  MODPOST 0 modules
make[1]: Leaving directory `/usr/src/linux-headers-3.0.0-12-generic'
rt73.ko failed to build!
make: *** [module] Error 1
Thomas Ward
  • 78,878
You do not need that patch, it is for much older kernels.
according to aircrack-ng.org: "This fix is already included in 2.6.31 and newer kernels, so this patch should only be used up to 2.6.30."
See posts #49 and #50 on this thread
http://ubuntuforums.org/showthread.php?t=1215251
Relevant excerpts posted below
Post 49
whoopsy, I guess you can inject with rt73usb right out of the box!
I simply used airmon-ng after install "iw"
sudo apt-get install iw
airmon-ng start <device>
Post 50
This tutorial only dealt with the legacy ieee80211 version of the RT73 driver (p_larbig/ASPj mods), hence why we needed to blacklist the mac80211 driver version.
The driver bundled with karmic is the mac80211 based one (which depends on rt2x00usb & rt2x00lib). That's why you needed to install the tool "IW" (needed for stacks-mac80211 interface management)
To understand the differences, see mac80211 versus ieee80211 stacks write-up.
Panther
  • 104,528
It is possible that the drivers are already installed.
Open a terminal and try this command:
sudo modprobe rt73usb
then this:
iwconfig
Do you now have a wireless interface?
