I have a new laptop that secure boot enabled with UEFI firmware. The main use would be for previewing media in a read only environment and preforming dd imaging of said media. What would be the benefits of a partition installation vs a persistent USB installation on a 3.0 USB? Does it matter which partition is used (ie: a volume that I shrink to add ubnuntu or an ssd drive added to install ubuntu.) Would a persistent USB installation be bootable with a secure boot environment?
This heavily depends on what you are planning to do on Ubuntu.
Option 1: LiveUSB
I would recommend this for trying Ubuntu, but not for a permanent System, because it will not have a very good performance.
Option 2: Virtual Machine
This may be a good solution, if you want to keep your current OS (Windows?) as main OS and use Ubuntu from time to time for specific tasks.
Option 3: Complete Installation
I would recommend this option, if you want to use Ubuntu as your main OS. You can decide for a dual boot configuration, if you want to keep your current OS. Regarding the question, whether to use partitions or two drives: This is also dependent of the hardware you have. Normally installing Ubuntu in a separate partition works fine. But you should consider using a different drive, if it is very small.
- 4,942
